Best place to get 'ignition hot' current from?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Jan 23, 2001.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Best place to get \'ignition hot\' current from?
    What is the best place on the fusebox to get ignition hot from? I need to hook up my tach and my elec. choke, where did you guys tap in?
    -- Mike
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Re: Best place to get \'ignition hot\' current from?
    Should be a terminal marked ign. This is only hot when you turn on the key.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    If you poke around with the key off and on with a multi meter, there are a few open places in the box that you can plug into.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  4. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Should be able to go to the hot side of the solenoid on your starter for the electric choke. In the fuse box there should be plug ins next to ignition hot items. You can also hook up to accessory items for the tack, try the plug next to the stereo fuse
    I thought I was wrong once,
    but I was mistaken
