Best place to hook a vacuum gauge up on TBI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadJap, May 28, 2003.
  1. BigBadJap
    BigBadJap Registered Member
    May 23, 2003
    76
    Alberta, Canada
    Hello! I would like to test the vacuum on 5.7 TBI and quite honestly, I have no idea where the best place to hook the gauge up is...
    Can somebody help me out? (Please be descriptive, I'm quite dumb... /forums/images/graemlins/wink.gif )
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If your '89 is similar to my '90, you can unplug the vacuum tube that goes to the front of the EGR solenoid and connect the gauge there, if you're just doing a quick test. The EGR solenoid is on the passenger side of the engine, on top of the intake manifold, just in front of the MAP sensor. /forums/images/graemlins/cool.gif
  3. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    There is a 90 degree fitting in the manifold between the EGR and distributor if you want a vacuum connection for a bigger size hose
  4. BigBadJap
    May 23, 2003
    76
    Alberta, Canada
    Eureka! I've found them both! Thanks for the help!
  5. Grim-Reaper
    7,385
    Atlanta
    THe EGR port may not get full vacum at idle. For testing I alwasy grab the HVAC vac line. You can grab it right behind the TPI in front of the distributor. If you want to be slick you can put a T in there where it's easy to get at and just cap it. Becarefull where you put the T. There is a Check valve in that line to hold Vacuum for the HVAC system. You need to be between that check valve and the manifold.
    Most of the ports on the TBI are timed for the emmisions crud is why I don't use them.
