Best place to purchase pyrometer?
Discussion in '1982-Present GM Diesel' started by DukeBoy88, Mar 30, 2004.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    I found this site
    http://www.egauges.com/eg_typeI.asp?Type=Pyrometer
    but didn't know if there was a better place to order from.
    I've used autometer in the past, what other brands are quality instruments?
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Ispro makes the best pyro I have used...... If you put one in your truck put it in post, not pre turbo. If you do opt for pre turbo make sure you take the exhaust manifold off before you drill to recover all of the shaving or you will destroy the turbo.
    John
  3. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    You can go to a semi truck salvage and get one from a freightliner or a KW and they are the 2 inch gauges. If you get one from a peterbilt they are the larger speedo sized gauges. You should be able to get the gauge and pigtail all the way to the turbo for next to nothing..
    John
  4. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    I have an Autometer pro-comp 2 5/8" guage in my truck. Kind of pricey, but I really like it. Got it from Summit racing.
    Casey
  5. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    Isspro makes a nice one. Color coded temp ranges and nice lighting. I'd go pre-turbo though. That's the info you really want. Otherwise, you'll be constantly doing math in your head. This place has a good reputation and decent prices.
