Best power steering belt maker?
Discussion in 'The Garage' started by Desert Rat, Jun 2, 2006.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I was talking to a mechanic and I asked him who made the best power steering belts, aka won't slip or stretch. He said to go with one that has the teeth on it like the Goodyear belts. However, he thought that the Goodyear belts tended to stretch too much and had to be replaced often. He recommended another brand which I promptly forgot. Any recommendations? He also said that if I was to put a smaller pulley on the pump, it would keep the pressure up better in low rpm situations like rock crawling.
  2. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    gates....
    but I use goodyear... and I have never had one break that I can recall.. I replace them about every 3-4 years.... as a part of maintenance
  3. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Gates, that was the one he recommended..
  4. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    Gates is the only belts I use.
  5. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Gates. PAD.
  6. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Sounds like I need to track down a Gates belt. Any comments on reducing the diameter of the pulley to increase pressure at low speeds?
  7. dremu
    Feb 27, 2000
    15,957
    446
    East of San Francisco
    I worry about running the pump any faster than it already does at highway RPM's.
    There are other ways to change the pump for pressure. Everything (or at least a lot of what) you ever wanted to know about the Saginaw style pumps:
    http://westtexasoffroad.homestead.com/powersteering.html
    If you're still using the compression (i.e. not O-ring) style fittings, I prolly have an extra one you can drill out if you wanna play with it.
    -- A
  8. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Well, I tightened up the slack in the belt and not much help. Now it squeals.
  9. dremu
    Feb 27, 2000
    15,957
    446
    If you mean the pump squeals (as opposed to the belt), you're in for some fun. Could be that the bracket is misaligned, could be the pulley, could be the phase of the moon.
    Monument has the Lucas Oil Treatment for PS pumps which does stop some squealing, fwiw.
    -- A
  10. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    NAPA sells gates belts and hoses .
  11. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I may try swapping in one then and see if it changes. I'm still having steering issues. When the truck isn't moving, and I turn the wheel, it skips and pulses like I've maxed it out at full turn. A shop told me that belt is slipping and to tighten it up. I did so, but no change.
  12. dremu
    Feb 27, 2000
    15,957
    446
    Pulsation can be attributed to TOO MUCH pressure. Do I remember you having a fancy PSC pump and maybe a stock box?
    -- A
  13. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Nope, the box is built by PSC as well specifically for the crossover application.
  14. dremu
    Feb 27, 2000
    15,957
    446
    That's bad then, if it's chattering. Yeah, try a new belt, or I'd call PSC and ask.
    -- A
