best price on steering components?
Discussion in 'The Garage' started by bigbadchev84, Aug 3, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    where is the cheapest plave to find a dropped draglink and a dropped steering arm the goes on the steering box?
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    how much lift you run? the drop links suck . if you need this much as you are looking for do cross over. just my idea. and if not ebay
  3. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    well i got a custom lift going on it is currently at about 13-14 inches of suspension lift, i am going to do the push-pull steering with hydro-assist with a 1" ram. i currently have the 3" block and the raised steering arm and i am still around 6" short
  4. sweetk30
    Nov 1, 2004
    25,546
    542
    you need crossover bad.:eek:
  5. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    What Is So Bad About The Drop Links?
  6. sweetk30
    Nov 1, 2004
    25,546
    542
  7. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    will the knuckle off of a 1/2ton 10b or 44 work on a 44 3/4t?
  8. sweetk30
    Nov 1, 2004
    25,546
    542
    same knuckle 1/2 ton or 3/4 ton but need old style dana 44 units with flat on pass side and get both as the tie rod goes on other side of knuckle arm. then have it drilled and taped . bolt it on.
  9. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Articulate? With 12+" of lift? It doesn't happen :)
    I have the stock-style steering correction kit off my 12" lift I may sell separate soon if I can't sell the whole kit by the end of the month. - it comes with a drop pitman arm, drop drag link, raised steering arm and a 4" spacer block between the knuckle and steering arm.
  10. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    haha that is what i was thinking, it wont be seeing much "hard wheeling" thats what i got the blazer for, this is gonna be 90% pavement pounder 10% mudbogs thats it, so i guess i will suffer through the 10% if it gives me problems, im gonna go hydro assist anyway. i already have the raised steering arm and 3" spacer block. all i need is the draglink and the arm that goes on the steering box. if you are willing to sell me just those 2 ill give you $150.00 if that includes the shipping. i can have a check in the mail monday if you are willing. thanks
