best rattle-can brand for axel painting?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Nov 19, 2001.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I am getting a new ff14b soon (thanks Brian!). The thing is apparently a lil crusty so I'm gonna wire-brush it and then rattle can it. Any hints on what brands of spray paint would be best? Application techniques? # of coats? As always, any help is appreciated, thanks!
    J
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    use lots of thin coats , and make sure its good and clean .
    dents ....
    O R D's axles
    NO BREAKAGE :)
  3. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    dents ....
    O R D's axles
    NO BREAKAGE :)
  4. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    dents ....
    O R D's axles
    NO BREAKAGE :)
  5. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    Yes, lots of thin coats, at least 15 minutes apart. As far as brand, I don't know, I havn't used enough to pick one over the others.
    A computer once beat me at chess, but it was no match for me at kick boxing.
    <a target="_blank" href=http://photos.yahoo.com/dana60manual>http://photos.yahoo.com/dana60manual</a>
  6. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
  7. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I wire brushed mine and sprayed on some black Rustoleum appliance epoxy. Just did one thick coat (I used the same paint on my wheels and the second coat ate away at the first[​IMG]). The finish came out super glossy and its holding up real well. Here's a pic:
    <a target="_blank" href=http://coloradok5.com/albums/album60/aaq.sized.jpg>Painted 14Bolt</a>
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers 14Bolt/ Dana44 4.10's
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
  9. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I use Rustolium Rust Stop satin black and the techniques mentioned above.
    Some people shouldnt drive anything bigger than their head.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  10. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    YES YES YES FRIZZLE FRY IS right ............ rustoleum SATIN BLACK.. you can get it at home depot.. its cheap..
    I did a car 12 bolt axle once with that paint and it turned out bitchin.. looked brand new... axles are not supposed to be glossy.. flat would "do" but satin is PERFECT. trust us :) get satin black
    I have some pictures if you want, email me
    mike
  11. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Its been about 3 months now... still looks as good as the day I painted them. That stuff is hard to scratch too.
    Rod
    Alameda, CA
  12. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I used VHT gloss black on mine (almost 3 years ago now). I cleaned up the housing with a wire brush, hit it heavily with engine degreaser (and rinsed with water), let dry, and then one last wash down with brake cleaner. Let everything sit overnight and then applied 10 or so *light* coats (prevents rusting and later chipping). It's made for high temps and resists fuel, oil, etc. I have dropped wrenches and ratchets on it (not on purpose of course [​IMG]) and it is still going strong.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  13. Eagle
    Eagle Registered Member
    72
    Suprise, AZ
    Here is a good and cheap cleaning tip. Buy oven cleaner. Spray it on and walk away. 15 minutes later spray it off. You might have to do this 2 or 3 times but damn. You can eat off of it in the end.
    There is a VERY fine line between hobby and mental illness
  14. hawglet
    hawglet 1/2 ton status
    Aug 4, 2000
    265
    Hastings,NE
    Wire brush the chunkes off then put some oven clean,like mentioned above, put a coat or 2 of a rust conventer primer on it, you can get it any where, wal-mart sells it even, then if you aren't going to be showing it brush on some exterior house paint let that dry for a dry or so then about 3 to 5 thin couts of some thing that lokks good to the eye as far as color any brands work fo rall of this, It does take about 3 days before you get to put it in but it will be bomb proof, and if it is just a beater don't even bother with the last step(spray can) that is just for looks anyways, so the wife/girlfreind won't kill you cause it doesn't look great!!!!
    Thanks, (in advance)
    Hawglet
    hawglet@excite.com
