best rebuilt for 700r4???
Discussion in 'The Garage' started by George_Pimpdaddy, Sep 12, 2006.
  1. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    Hi there im taking my blown 700r4 in to the shop to be rebuilt and im wondering if there is any things or extras tht i should be thinkin about? its from my 89 blazer 4x4 full size i already have the tranny out and called around and found a known tranny builder in the area. im gonna get it rebuilt there for a rough cost of $800 canadian with a new torque converter of course. are there any upgrdes tht i shouldnt miss im thinkin about a shift kit as well as i bevieve that it had one when i bought it but not to sure now of the brand or stage. will that beable to be reused or should i be asking for a new one? im trying to keep the rebuild cost low since i got more stuff to do to the truck :doah: thanks guys:bow:
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    This has been covered a few times quite recently. A search should drag up all the info you need.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I would just let the tranny builder do what he usually does to them if you want to keep costs down.
    A trans pan with a drain plug in it would prolly be the best mod you canb do. Fresh clean oil will keep a 700 alive a long time.
    Be sure to clean out your tranny cooler/lines good before you install your new trans.
  4. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    i dont know much about transmissions but ive heard a common upgrade is to put in a corvette servo. amyone know anythin about this mod?
  5. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,234
    58
    American Fork, Utah
    In a nutshell, corvette servo, Beast sun gear shell, 4l60e teflons for reverse input (on pump), Z Pack 3-4 clutch pack or good commercial clutches with 8 or more frictions, and good thorough overhaul with usual updates that any good trans shop will do will make a long lived trans. Don't forget a good big cooler and a trans temp gauge.
  6. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    what is different about the vette servo? and what would it improve? i was thinking of doing a shift kit and maybe a vette servo to my 700 not that it needs it i just want a better performing tranny. shifts are a lil on the slow side, and a lil firmer shift would be nice
  7. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    My 700 had a corvette servo in it. It would shift hard in to second. To hard imo.
  8. bigblock72
    Oct 18, 2005
    1,234
    58
    American Fork, Utah
    The Corvette servo has more apply area so it holds the band tighter and firms up the second gear shift. Makes a nice upgrade with shift kit, I like to run type F fluid to firm up all the shifts. Make sure to install while you have the pan off, sometimes the band likes to pop out of place so the apply pin doesn't engage right. If you have the pan off you can see if the servo is pushing the band.
    If you want a real firm shift go to a billet servo (second and fourth) and a wide band, then it'll bark the tires on every shift and knock the mirrors off, and break the back window out, and............it's pretty cool.
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    This is what I've done along with a Transcat kit but I'm seriously considering taking the billet servo off. The 1-2 shift a WOT is vicious. I'm sure it's going to break a sprag or shaft.
  10. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Is it the kind of upshift that is all right for a 2500 pound vehicle, but a bit to hard for a 4500 pound vehicle? I can see that.
  11. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah, in a lighter vehicle it would probebly just light the tires up but in my truck it's like getting hit up the rear by a semi. It sounds too harsh to be good to me so I'm just laying off WOT shifts for now!
  12. George_Pimpdaddy
    Oct 17, 2002
    1,306
    thanks for some of the info also is my 89 tranny gonna be mostly factory updated? like have most of the problems fixed throughout the years? thanks for the input guys :bow:
  13. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I had most of that stuff done to my 97 K1500's 4L60E. Corvette servo, kevlar bands, extra clutches .. but they also drilled out the valve body to allow more fluid flow. 1st to 2nd is a bit firm, but not too bad at all.
    It's been going strong for about 5 years now, no complaints at all, I'm very happy with it.
