Best sealed beam conversions for the money?
Discussion in 'The Garage' started by guido666, Nov 14, 2005.
  1. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
  2. originalspanksta
    originalspanksta 1/2 ton status
    Jan 31, 2005
    147
    Philadelphia
    we converted a buddys 78 k10 with the hella kit, its awesome. so many more bulb choices to upgrade the lights now.
  3. guido666
    Feb 16, 2005
    788
    Longmont, CO
    They use H4 bulbs as well right?
  4. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    I have used 2 of the "h4" conversions on your list both the cheap JC whitney ones, and the Hella models. I was unhappy with the beam patterns of both of them and have since installed some CIBIE's they are about the same price as the hella's but the beam pattern is much sharper and clear. The cibie's along with 12guage wire and relays are the best driveability upgrade i have done and would recommend them without any hesitations.
    After a liittle searching, trial and error i have found the following places that seem to sell the best parts for the conversion in an offroad vehicle.
    Cibie ecode lamps with lexan stone guards- Danial Stern lighting
    Waterproof relays- route66supply
    Bulb sockets part number HL28101- Rally Lights
    For wiring i use Ancor marine grade wire exclusively, and it can be ordered online or any westmarine dealer.
    The Danial Stern Link has more information on vehicle lighting than any other place i have seen on the net.
  5. guido666
    Feb 16, 2005
    788
    Longmont, CO
    What difference does it make if these lights are for "right hand drive" functionally? (I understand that they are technically illegal because they haven't been DOT certified). I just mean is there a functional difference?
  6. ncgamedog
    ncgamedog 1/2 ton status
    Oct 7, 2005
    130
    union grove, north carolina
    LMC truck has them right now. the lens are crystal clear, witch i like. same price as jc witney. euro lamps they call them. they dont look too rice as long as you dont run the blue bulbs
  7. rugger03
    May 14, 2000
    829
    around
    its the way the lenses are cut, right hand drive lights angle the light up on the passenger side so you can see road signs and things on the side of the road. the light in front of the car actually focuses across a sharp plan so it reduces glare to both you and oncoming traffic. I run 65/100 watt bulbs in mine and never get flashed for my low beems being to bright.
  8. guido666
    Feb 16, 2005
    788
    Longmont, CO
    So do American lights do the opposite (and angle up on the right side) or are ours just generic? (Besides sealed beams of course which are all the same.)
    So Rugger03, you're running these CIBIE lights too?
  9. guido666
    Feb 16, 2005
    788
    Longmont, CO
    I better take the 8' whale tail spoiler off the back then. :rolleyes:
  10. rugger03
    May 14, 2000
    829
    around
    American lights do not limit the direction and focus of the light pattern as much as the E code lamps. sort of hard to explain the pattern of the light out put, but if you pulled up to a wall on level ground and looked at the pattern of the lamps it would be a perfectly straight line across the front of the truck and at the right hand side it angles up at about a 45 degree angle.
    Yes i currently have the Cibie "ecode" lamps and have personally tried the Hella Ecode lamps and the cheap H4 converstions. your only fooling yourself with the cheap converstions and the hellas are close in price to the cibies but a lower quality unit.
    I have no connections to any of those places and dont get any sort of hook up, I just learned by trial and error. Driving on back country roads at night with deer jumping out make you think about the best lighting possible.
    Read the danial stern web sight lots of good information there, or send him an email he is very straight forward and honest, and will answer any question you ask very quickly from my experience.
  11. guido666
    Feb 16, 2005
    788
    Longmont, CO
    So here in the US I should install the one they say to use on the left side, on the right instead?
    I'm really glad I talked to you guys on here, or I would never have found out about these. And I definately don't have the money to do the trial and error thing.
  12. ncgamedog
    Oct 7, 2005
    130
    yeah i am wanting to do a high quality sealed beam replacement myself. but i'm geting confused w/ all this just tell me some part numbers so i can get them coming. i work third shift and i constantly see deer a little too late to do much ajusting to avoid them.
  13. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I have used the mid priced JCW conversion lights with good results. These are quite old though, no idea if the current stuff compares. I also have two sets of Hella E-code large rect. headlights and I'm not nearly as impressed with them.
    A common H4 bulb is 55/100, which is a legal low beam. I use those in my truck and my DD is about to get a set (own them, not yet installed).
  14. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    i have Generic type #3 with 100/55 bulbs right now and the only way im happy with the beam pattern is to point it so high everyone flashes their brights at me...
    but it still totally kicks ass over the sealed beams... seems like it puts out more light on low than the sealed beams did on high.
  15. guido666
    Feb 16, 2005
    788
    Longmont, CO
    What part of the beam pattern weren't you happy with?
  16. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    FWIW, I installed a Bosch H4 conversion kit on my 84 about 5 years ago. I've said it before and I'll say it again- it was by far the best $100 I've ever spent on the truck.......
  17. mechted
    Oct 19, 2003
    765
    Granbury, TX
    the pattern is all screwy for low beams... they flood a fair amount of light really close to the front end of the truck, then theres a bright spot out a good 30 feet or so (hard to judge while moving) but there is almost no "flood" effect past 30 feet...
    the high beams are nice though... can see down the block no problem
    truth be told i need to re-adjust them again, and im probably being picky about the pattern
    for $50 its a nice upgrade... something to think about
  18. guido666
    Feb 16, 2005
    788
    Longmont, CO
    It sounds like the only ones people are happy with are the CIBIE ones. And for the price, they really aren't any more expensive. The cheap ones are $20 a piece, and the CIBIEs are $60 a set. No big deal, so long as I'm getting the right thing first, instead of trial and error. Do the CIBIEs include the connectors for the back of the lights? (I can wire a relay setup myself no problem, I just need to make sure I have the proper lightbulb adapters/connectors.)
  19. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    $$60 EACH.......................??? :(
  20. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Yes "7" Convex/Dome-face H4 high/low beam: $59/ea" you are correct, my bad. I still think it's a good idea, I'll just have to wait longer to save up the cash. :rolleyes: This brings up a good question I had but thought was stupid before, so would you recommend getting two of the same kind (either the "just flat across" beam patterns, or the "flat across and shine up at the signs" ones). Or would you go with one of each? Will they even let me order them like that?
