best sealent for dual t-cases? Copper ok?
Discussion in 'The Garage' started by BranndonC, Oct 19, 2005.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i have the dual transfer case kit from NWF and put it together using fipg (a toyota engine oil pan gasket maker) and it leaks in many spots, anyone know which gasket maker works the best? also i'm running tranny fluid in both the 205 and 205, is their something better i could be running?
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    yeah but i kinda forgot something when putting it together the first time, so that one is ruined, can i use cork gasket from pep boys?
  4. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    Branndon,
    Cover the postage I'll get you the proper gear, Sillicone sucks.
    We recommend 80-90W, but the 205 was run with ATF from the factory, I just don't like some of the characteristics, I have seen a bit more tooth wear in the ATF cases vs. 80-90W.
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    wow, awesome! Thanks! and you mean 80-90 in the 203 and 205? is it possible to back track and get into the th400 from the 203 if i do it this way?
  6. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    80-90 in the 203/205 is fine, asw for it getting into the trans there is a seal in the trans to tcase adaptor to prevent this.
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Boy wasn't that an interesting day. :haha:
    Ira
