Best stock torque converter
Discussion in 'The Garage' started by Triaged, Nov 21, 2002.
  1. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have gone over all this high/low stall stuff in my mind.
    I finally desided I want it exactly as it is right now but mine is shot.
    So who makes the best quality for the best price and where can I get one?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If you're talking about hi-preformance, I've always gone with TCI. /forums/images/graemlins/thumb.gif
  3. Geno
    Geno Registered Member
    Nov 18, 2002
    52
    Dorchester, Nebraska.
    I just finished putting in a TCI 2000 stall converter in my jimmy, I like it, I think they call it a saturday night special, it is about 500 or 600 over stock. I run 35 inch thorneburgs, 456 gears, 3\4 ton running gear, 205 transfer case th350. Works for me.
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I don't want a high stall...or a low stall.
    I want a factory stall.
    I guess what I'm asking is does TCI or B&M or someone else that is a good brand make a stock stall converter?
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Yes, you can get stock stall speed converters from both TCI, and B&M.
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    My factory torque converter had a stall speed of about 1500 rpms back when I had a 350 engine. I would call that low.
  7. ratlover
    ratlover 1/2 ton status
    Aug 5, 2002
    215
    Peorial IL
    Run from B&M.
    Call the converter co.s and tell them what you have and what you want it to do. A converter that will stall at 2 grand behind a 305 will stall a whole lot higher if its put behind a blown 632. Know what I mean? The converter manufacture should be able to tell you what it will stall at exactly behind the motor you have. When they list a stall in say summit for a particular converter it will vary quite a bit depending on what motor its behind, those #'s are kinda pointless IMO except to reference them against themselfs. Even a converter that says it will stall at a certian RMP from one manufacture wont stall the same as from a nother manufacturer. TCI, ATI, Coan, Continental. ATI rockss but might be outa your pricerange.
    Finding the exact strall of a converter is very hard to do.....you usually overpower the tires before you get it to stall. a 1500 stall is pretty low and about stockish depending.
