Best sure fire way to adjust valves
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Jan 14, 2002.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Ok, I now understand the valve seal deal.
    So my uncle was rattling off all this info and just left me in the dust.
    So get #1 at TDC buy looking at number 6 to see when it starts the move. This is when I "know" for sure that Im at TDC, then tighten them down till they are not giggling anymore and then 1/2 turn more? Does this sound right? Or did I miss some good info in there somewhere?
    Then go on the #8 and so forth?
    Still hoping the GOV'T will ban the use of loud stereos with RAP music. [​IMG]
    <a target="_blank" href=http://www.mccords.s5.com/myk5/index.htm>NashvilleK5</a>
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    I've spent a LOT of time under the hoods of various vehicles over the years, but I've yet to hear any valve train parts giggling! [​IMG]
    Seriously, with the lifter on the base circle of the cam, spin the pushrod between your fingers as you tighten up the adjuster nut on the rocker arm. Stop when you feel the pushrod just begin to get hard to spin. Tighten the adjusting nut another 1/2 turn. Now you're ready to move on to the next valve. [​IMG]
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Giggle wiggle, same thing. [​IMG]
    Do I still need to get each piston to top dead center?
    And how hard is "starts to get hard to spin"?
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    As long as the lifter is on the base circle of the cam you're fine. I seem to recall you can do half the valves at #1 TDC and the other half at #6.
    With the motor at #1 TDC you can adjust:
    Exhaust...1,3,4,8
    Intake....1,2,5,7
    Now turn the motor one full revolution...which should be #6 TDC. Now adjust:
    Exhaust...2,5,6,7
    Intake...3,4,6,8
    You should lightly spin the push rod in between your fingers as you tighten the rocker in question. You'll feel some resistance to rotation when you reach zero lash...from that point turn the adjusting nut 1/4 to 1/2 turn more.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Is this another one of your Canadian "fabrications"? [​IMG]
  6. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Just a question for the books. Is the duration of a cam ever long enough so that you cant adjust half the valves while the engine is at TDC of the compression and the other half at TDC of the exaust stroke (for the number1 cylinder). (Just as Trusty was describing) Theoreticaly you could have a large enough cam with a long enough duration to where the lifter on many of those valves would not be on the base circle of the cam. Right? And if so, about how large does the cam have to be in a SB for this to be true?
    When all else fails... Check the blinker fluid.
    78 K-5
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    as-sphinkter-says-what?
  8. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    So are you saying that trustyk5 knows what he's talking about or are you saying that is full of [censored]?
  9. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    oops Im sorry, I said the S word!
  10. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    But for real.... I trust my uncles way is cool TDC on every Cylinder....But Rene's way, if coshur for a stock cam would be alot faster I must say. Is there any more input here? The more the marry-er
  11. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I did mine like I described and my cam has 260 degrees advertised duration...
    If you want to spend all day finding TDC for every cylinder though I guess that's up to you[​IMG]
    Rene
  12. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, Rene, you know that I dont want to do that...... I just want to make sure I know what the hell Im doing before I dive in there!!!
  13. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    Like you don't believe Renee or sumthin? He is not gonna steer ya wrong I wouldn't thi nk. I have built small blocks and that is the way it is done. If you want to get a degreeing wheel and degree the cam and do the adjustments that way is fine too and VERY time consuming. There is a base circle to all cams and never seen so much overlap that would simply throw off a base circle to the point you couldn't manually adjust valves. Not even in racing cams with .300+ duration and valve lash set with feller guages. I don't understand what it is that you are asking then about base circle and not being able to manually set up valve sequences. if that doesn't answer the question.
    Neil H. Alabama.. "It's a full size thang, Jeep owners don't understand!!" '78 K5 400ci 4x4 AT,AC,PW Cheyenne., '74 C10 4x2
  14. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    It's quite straight forward...if it makes you feel any better I cribbed the procedure out of my Chilton's manual.[​IMG][​IMG]
    Rene
  15. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I didn't aks the question, I was just following up on dudes comment. It sorta sounds feesable, but Im not a true gear head, I just have an imapt ability to get myself in the positions to make myself figure things out nad by all means I will find out, the hard way or the easy way. So I was just asking questions, trying to pry more info out of all you spoiled picture whores. [​IMG]
  16. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    <hr></blockquote>
    Woohoo...i resemble that remark.[​IMG] Are ya gonna take some pic's when you adjust yer valves sparky?[​IMG]
    Rene
  17. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Just for you I will! [​IMG] I'll have hte nieghbor come over and play photographer while I supply him with beer. [​IMG]
  18. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    My camera will store 80 640x480 pics. So I'll tell him to go crazy. .....
  19. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Start by getting those rockers not engaged to be 1/8th turn past loose. Theres plenty of info above on how to get there, Then...
    You can purchase for dirt cheap ( 8 - 12 bucks at any napa)a set of oil squirt clips that fit on each of your stock rockers which prevent them from squirting oil everywhere. Leave the valve cover off and start the engine. With the engine idling (dont rev it or it will get oil everywhere) take a socket to each rocker and loosen it untill it ticks. Now tighten it very slowly untill it barely stops ticking and then slowly a 1/4 to 1/2 turn more. I usually use only 1/4 turn as some lifters allow you to steal a little lift here but its all conjecture really. Repeat this step for each valve. Button it back up and repeat this for the other side. Youre done.
    All the old timers at the drag strip do it that way, they've got me doing it that way and frankly its easy and works like a champ every time. Good luck!
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://24.55.50.76:81/k5/> Pictures</a>
  20. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Now see???? More good sounding info....Do we have a second?
