Best Synthetic Oil (and why)
Discussion in 'The Garage' started by guido666, Dec 1, 2005.
Which synthetic motor oil is best?
  1. Valvoline SynPower
    5.8%
  2. Mobil1
    43.2%
  3. Castrol Syntec
    8.9%
  4. Amsoil
    21.8%
  5. Havoline
    0.4%
  6. Royal Purple
    14.4%
  7. RedLine
    1.6%
  8. Other (please post and explain)
    3.9%
  1. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Who uses what synthetic oils, and why are they the best? Figure in cost to the equation.
  2. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    I chose Pennzoil synthetic. I run this is EVERYTHING I own, have never ran anything else and will continue to run it. Owning and operating a speed lube sponsered by Pennzoil there are many things learned and seen in the oil industry. Pennzoil synthetic has a additive, which was developed by Pennzoil for NASA for the space shuttle. They made it for the hydraulic systems, since it is so cold in space you need something that holds up. The additives in it resist heat, cold, and dry starts, and has time released protection technology. Seeing many oils used (not naming any) there are some oils out there that go into an engine not as slick to the touch as pennzoil synthetic is when it comes out in used forms.
    I could go on and on, but as for me this is the only synthetic I will ever use!
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I chose Redline , because it still looks good when I remove my locker to inspect it . And because of the fact that my other 12 bolt has been sitting for almost a year with the cover off , and there is still a good coating of Redline on it , since it sticks to metal so well :D
  4. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i use mobil1, first b/c it is just a great oil, second it's the only one i've ever used, third it stays clean for it's whole service. i like to stick to one kind of motor oil b/c i don't like the idea of mixing additives with other brands.
    probably the only synthetic i would never consider is Pennzoil. it may well be a good quality oil, i don't know, but i do know that at one time i had the misfortune of working for jiffy lube and have absolutely no respect for that company. pennzoil owns jiffy lube, and therefore, in my opinion, jiffy lube represents pennzoil. since there is not a single ounce of quality or anything good about jiffy lube, and pennzoil doesn't do anything about it, i can't really respect pennzoil - at least as a company. i tend to place a lot of value on the quality of the company when it comes to products. it's like schucks - i've rarely ever had good service from them and even if they might have the lowest price on something, the chances of me going in there are little to none. just my .02.
    colby stephens.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    All the oils you listed are good. The really important thing you must remember is to pick one and never use anything different. Changing oil brands will have a negative effect. I use Honda oil. It is semisynthetic and it is cheap for me. It is made by mobil.
  6. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Why will it have a negative effect?
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    always used mobil1, always been very happy...so why change?
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    from what i understand, the cleaning agents will fight eachother and your gaskets may get in the middle of that rumble, if you will. i suppose that might even be the same concept concerning friction modifiers. Someone correct me if I'm wrong.
    Colbystephens.
  9. guido666
    Feb 16, 2005
    788
    Longmont, CO
    So could you run a change of natural oil in between to help flush it out?
    Because not knowing that was a problem, I had been running Valvoline DuraBlend, and just did an oil change with Castrol Syntec (it was on sale for $3.50/qt!!).
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i would avoid going back to a regular oil - i've heard worse problems about going back to standard from synthetic b/c the cleaning agents are often stronger. I would say you probably don't have anything to worry about - just try and stick with one oil. You will probably not see any problems from doing the change once. Maybe you'd see the effect if you regularly did the change for a long time - but then what's your standard by which to compare? In anycase, i'd say leave it. If you really were concerned, you could get engine flush additives, but make sure its not the kind with kerosine - as this has the potential to dry out seals. Again tho - i wouldn't worry about it. i've heard great things about castrol - so just stick with that from now on.
    colbystephens.
  11. dallassmith
    dallassmith 1/2 ton status
    Sep 19, 2004
    142
    ABQ,NM
    Amsoil
    long service life....can do oil testing on your oil to see whats happening to it.
    offer an engine flush when you switch oils
    best oil filters
  12. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I always see tons of debate on these oil posts, but not any hard proof, or real world examples. I personally don't have a clue what is best to run. I'm getting 350 to drop into my burb this weekend, and I thought about switching to synthetic. Would that have any negative detriments, other than to my wallet? I may just stick with natural, because its cheap.
  13. dallassmith
    Sep 19, 2004
    142
    ABQ,NM
    I have run about 24k on one oil change...but that is with a filter change at 12k and then adding a qt. I have not had a problem with anything.
    I run it in every thing that takes fluid. I find that it runs cooler than most oils.
    Just depends on if you want to spend the money $5-8 a qt for syn and have it last for awhile, or spend less money and change it more often to end up spending more money than it would have cost to run syn.
    :dunno: :dunno:
  14. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Sorry to interject, but most of the suggestions I'm seeing are based on "I heard" or "from what I understand". There's a lot of crap flying around out there today, and most of it is misinformed and biased. I would prefer to base my opinions on evidence and reasearch, not hearsay and assumptions.......
    Click HERE for an indepth look at what oil is and how it works.
    Click HERE for a comparison study. It's on the Amsoil site, but it was actually done by an Australian performance car mag.
    HERE is another link I found. It's on the Amsoil website as well, so keep that in mind.
    Anyhow, click away, brothers.......
  15. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Using Mobil 1 right now.
    click-click-clicky-click
  16. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I run Castrol GTX, Castrol Syntec, and Mobil 1. It all depends on the weather conditions, the intended use of the motor, and the kind of life expectancy I anticipate relating to contamination.
    I won't run Pennzoil, Quaker State, or Havoline.
  17. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
    I always find it funny how people never really consider what the drag racers run. They have the most extreme conditions, and I would think that they would have a pretty good idea what is the best, especially those who do it as a hobby without being sponsored and have to make their engine last longer.
  18. erik59
    erik59 Registered Member
    Jun 4, 2005
    52
    Parkersburg, WV
    Don't most drag racers tear down their motor after every few runs or so to check engine internals? I doubt that the oil that they use ever has more than 10 min use.
    I have used amsoil with great result as a motor oil, but like Redline as gear oils. Redline shifts like butter. Had a truck that burnt about a half a quart of oil every 3k miles and switched to amsoil and haven't burnt a drop since. Just changed the filter like they said. It costs more, but it is just so much better than dino oil. Why do you think that corvettes, and an increasing number of high performance cars come from the factory with Mobil 1 syn.
  19. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I used to run Mobil 1 in my BBC street/strip motor in my camaro. Then i found some tests where they came in almost last, and the top three i believe were amsoil, redline, and kendal...
    So i switched to Amsoil in my big block.
    For my k5's small block i'm still running mobil 1 right now though..
  20. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    click here to read what Popular Hot Rodding had to say about Quantum Blue Motor Oil. The paragraph called "lube considerations" tells the tale.
    Noted automotive author David Vizard says it beats mobil one for anti wear, and you can call the folks at BND ( or visit their website ) to learn more. shear / viscosity stable to 6,000 degrees, wear and friction cut in half. they'll also blend you gear lubes and tranny fluids with the same technology, per your application.
    On a personal note, my 87 K5 qualified for a warranty from titan labs, based on it's oil analysis looking so good. they would have paid me a thousand bucks to fix it if any covered part died from a lack of lubrication. In addition, my dad's C5's piston slap went away after using quantum blue. every vehicle in the family has run it for a few years now. my 92 uses the 5w30, so I get better mileage, without worrying about film strength.
    Anyway, check 'em out,
    Tom
