Best thing to do, Rebuild or Buy New???
Discussion in 'The Garage' started by Jeremy_C, Dec 8, 2002.
  1. Jeremy_C
    Jeremy_C 1/2 ton status
    Mar 26, 2002
    1,381
    East TN
    My 350 dropped dead thursday. It sounds like it threw a rod cap, as far as i know it didn't crack the block. SO rebuilding is an option. The motor had a little work done to it, aftermarket heads, slightly bigger cam, bigger pistons, an was bored .30 from what i was told.
    The other option i'm looking at is buying new, i've never done this before, and I know alot of you have. Where is the best/and least expensive place to buy a new motor, and are they really worth it? I know places like Auto Zone an Advance sell new motors, but i cant imagine they are worth much.
    Let me know fellers, i'm all ears. /forums/images/graemlins/ears.gif
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    If it was me I'd keep the aftermarket heads and get a new motor to put them on. I would start looking here For that new motor A crate motor would a good start.
    Eric
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    This is the way i see it...most rebuild shops bore the cylinders and everything using the same thing for every engine. That means there are slight variations for each cylinder, and they wear out faster. Seems like most go for about 90-100K before they start smoking a lot and get tired. Thats not every rebuild shop, but most of the cheaper ones, where you can get an engine for $1000 or so. Spend a little more, like maybe $1800 and you can get a new crate motor from GM with all the factory tolerances, built by GM and just like your old one was new. Should have no problem getting 200K out of it if you take care of it. Thats what I'm doing when mine goes out
  4. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Personally, I would prefer to rebuild it. I prefer rebuilding because you can have it built the way you want it and it's a lot cheaper most of the time. I had mine rebuilt this summer and it cost me about $900 for the machine work and parts. I also had the machine shop put the short block, minus cam, together.
    What I had done:
    bored .030, honed with deck plate
    KB hyp. pistons
    Comp Cams 4x4Xtreme 262 grind
    new bearings, rings, etc.
    ground crank
    resized rods
    welded crack on starter mounting hole
    Pete Jackson gear drive
    heads rebuilt a couple years ago
    Performer Intake
    HV oil pump
    The shop I used is very reputable. They have built race cars in the past and two mechanics I trust also use them. If you decide to go this route ask around to find out who other people recommend. Most places will also offer a warranty if they assemble it.
    If you dont have any machine shops in your area that you feel you can trust I would go the crate engine route.
  5. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    Dayum....that sounds like a helluv a deal /forums/images/graemlins/thumb.gif
  6. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    Another thing, how much HP do you think all that gave ya?? Was it worth it?
  7. 4x4Freak
    Apr 21, 2002
    792
    Lubbock, TX
    I've actually got about $1200 into it right now including everything, the $900 was just the machine shop costs.
    I'm guessing that it's putting out about 350 hp and 400 lbs. I took it to the dunes Thanksgiving and I could definitely feel the torque and it was awesome.
    I plan to put vortec heads and TPI on it and hopefully get it to 400 hp and maybe about 420 lbs.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    In a 4x4, I'm more after low end torque the upper end HP. If you're rebuilding, think of getting a 383 Crank kit (Includes Crankshaft, connecting rods, pistons, ...ect. You can order it for higher compression if you wanta have more torque and hp. Most machine shops can order and assemble it for you with a warrentee.
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    I have $2000 in to mine that i built but i didn't rebuilt one i started with a bare block and got everything for it
    speed pro forged pistons
    comp cams 4x4extreme
    melling oil pump
    moroso aluminum valve covers
    i only had about $450 on machine work. but i also bought a reground crank (cheaper). i put forged pistons in it incase i want to run nitrous. just my .02
    TJ /forums/images/graemlins/truck.gif
  10. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I say rebuild it yourself. It's more fun, you learn a lot, and you can be sure you no one's gonna cut curners with cheap parts.
