Best tire pressure for sand????
Discussion in 'The Garage' started by dynoram, Jun 22, 2004.
  1. dynoram
    dynoram Registered Member
    May 27, 2004
    13
    Hey all ! well this weekend im going wheeling at a local beach. I have pro comp 32*11.5 mud terrain tires. I hope these things work in the sand the way they do in the mud /forums/images/graemlins/whistling.gif. but what tire pressure do you think i should try running em with.???
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    about 15 psi
    /forums/images/graemlins/usaflag.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    As low as possible without blowing a bead. /forums/images/graemlins/wink.gif It will depend on your rim width, but just air them down until you get a nice healthy bulge in the sidewall at the ground. The idea is to increase the contact patch so the tire floats.
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Shaggy summed it up.
    Sand?
    If they're 16.5 rims, go like 20psi.
    If they're 15's or 16's try about 10psi and that will make a big difference in traction out in the sand.. /forums/images/graemlins/peace.gif
    I run my 35x 12.50x 15 mud terrains on 15x10 rims at 8psi in the sand. Never blown a bead.
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I used to go to the dunes in Northern Michigan..
    Changing tire pressure didn't change traction much..
    Get ready for some outside tread..wear!!
    I used to round my tires..
    Have Fun!!! Get some AIR!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  6. kombi59
    kombi59 1/2 ton status
    Nov 15, 2002
    197
    Hey man I run 8 lbs in the rear 9 or 10 in the front we go to the sand dunes in yuma almost every weekend and this works best for my set-up. smooth ride lots of traction. have'nt popped a bead yet in sand, but have spun the tire on the rim. right out of balance. good luck.
  7. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Maybe Michigan dunes are different. I notice quite a difference in the sand with low pressure.
    I always see people drive down onto the sand at pismo oceano dunes with like 35psi in their tires, even in 4wd they'll start getting stuck and just bury the truck down to the axles. If they stop as soon as they start getting stuck and not going anywhere... and air the tires down to about 14psi the truck pops right out of the hole it just dug itself into. /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif
    And take some pics!...and then get ready to fix some broken chit!! /forums/images/graemlins/histerical.gif /forums/images/graemlins/whistling.gif
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/1zhelp.gif
    [​IMG][​IMG][​IMG]
  8. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    LOL...I was only running 33" BFG MT's
    Nice shots!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    I go to Silver Lake, Michigan and I watch people all the time TRY to climb hills without airing down. They end up burried to there axles.
    I run my BFG Mudders at 8 psi on soft sand and 12-15 psi on wet. I run higher psi on wet to keep from spinning the rim or busting the bead (I busted the bead only once running at 8 psi on wet sand....sucks!
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    up at silver lake i run at 10 psi on the 265/75/16s. the tire looks completely flat, i wouldn't wanna run any lower with these tires. i got great traction you must air down for sand, you will get stuck. i dont think there much difference in traction between 8-12.
    my friend on his toyota pickup ran 4 and kept getting stuck, he aired down to 2 and was better so he went down to 1 and did great till he lost a bead and almost rolled his truck.
    hopefully i can go up there on the 4th and be a little taller and bigger/wider tires /forums/images/graemlins/deal.gif
  11. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    I run 2-3 psi rear and 4-5 psi front...but I am running 44's so you are gonig to want to go higher than that.
  12. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Hummm...maybe that was my problem...
    Years ago...I was affraid to go below 15 lbs...
  13. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Ditto. I used to always see this when we used to go to the Outer Banks.
    Then last summer at Sand Dunes Nat'l Monument I saw people doing the same thing. Tearing up the trail. Had to get out and make about 5 trucks air down. Mostly guys in new SUV's with the A/C on of course.
  14. exrider
    exrider Registered Member
    Jun 5, 2004
    30
    When I going duning in Glamis, we run about 15lbs, give or take a few. Hugh difference especially with a full trailer and back of the truck loaded. More contact patch better = better traction, more air = get a shovel and tow truck.
    Red Riders Rule !! /forums/images/graemlins/peace.gif
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just take the cores out. /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
