Best tires for snow?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blackdog, Aug 18, 2001.
  1. blackdog
    blackdog Registered Member
    Aug 8, 2001
    98
    New Jersey
    <font color=black>OK, just thinking ahead to this winter, which is about the time I'll have the money for new rubber, what's the consensus on the best tires for snow? I've seen a lot of references to keeping them narrower (10.5 vs. 12 for example) but what about tread type. Would something like BFG Mud terrains fit the bill? Or maybe MT's with lots of sidewall bite? I live on a back road with one of the only freakin' hills for about 25 miles. This is the only way in or out, and it sucks getting stranded when it's covered with snow. Even 4x4's have trouble with it sometimes. Just trying to get every possible advantage, you know?
    Oh, and in snow and ice do you still want to keep the tire pressure low for traction, or is it the other way around?
    <font color=black> "Where did all these people come from, and how soon can they leave..."
    -OLD 97's</font color=black>
    <a target="_blank" href=http://www.k5.batcave.net>www.k5.batcave.net</a>
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    any mud type tire will do ok in the snow (ok any good mud type tire lol) i have seen bfg mudterrains do very well in the snow so do swampers my preferance in the snow is to have a wider tire like a 12.5 rather than a 10 so that it will stay ontop of the snow and yes lower air pressure in the snow is better than higher air pressure
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I personally like the Goodyear MTRs for all around traction. They hold up really well. I can vouch for that. When I rolled my truck two off them came off the bead, and one of them was rapped around my front suspension and they both beaded right back up. You want to keep the pressure up. Lowering the press with make it wider. You want narrower so you can break the first layer of ice.
    86 Blazer 4"lift 35" MTRs locked front, still 1/2 ton axles.Other vehicles 69 Firebird with 525 hp,and a 70 GTO www.geocities.com/modifierperformance
  4. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    When I was station in Iceland everybody ran FunCountries Dick Cepeks expensive. 33X14.5 or 36.5x16.5 I ran the 36's air down in the snow was great. The TSL I had were decent but when they couldn't chew to the ground all you did was spin..
    Eat More Mud!!!
    DREAMING OF A BIG BLOCK!!!!
  5. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Man you are already thinking about the snow? Me too. I will take cold weather any day over hot! Can't wait for the snowboarding...
    Surfing is Life...
  6. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    remember if you dig through the snow you hit ice and sipes help on ice my ATkos did great in snow and ice but im thinking of siping a set of mts to see how they do .
    88k5 silverado w4"lift <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  7. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Lat winter my 31x10.5x15 BFG AT KOs really did well for overall performance. They got me thru all the slush that was on thre ground and the only problem that I had was going up a 15% grade. Tell me one tire that could have gotten up that kinda of grade in slush at 10 mph. I did a fender check with a guard rail and just waited for a plow to clear off the road. That was stupidity on my part for taking the back road home in a slush storm.
  8. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    first of all are you actually talking snow, or are we talking ice, or a combination of the 2???
    ice, the more sipes the better and the pro comp at is extreme weather rated... actually here any decent tire studded...
    snow??? mud tires clean the snow real well, but the are terrible on ice...
    a good in between??? personally I'm running BFG AT ko's on Jedi Mind Trick with is my on-road k5, and I live in WY so I'm going to see a good combination of both!
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  9. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    General Grabber AP's are flat awesome for snow and ice - not the most aggressive tread (closer to least aggressive) you can get, but extremely effective, with lots of siping.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  10. blackdog
    Aug 8, 2001
    98
    New Jersey
    <blockquote><font class="small">In reply to:</font><hr>
    ...I had was going up a 15% grade. Tell me one tire that could have gotten up that kinda of grade in slush at 10 mph.
    <hr></blockquote><font color=black>Actually, the grade here is probably a little steeper. You get used to making sure you have enough supplies to last a few days if you get a big storm (private road: county doesn't really plow unless you give the plow guy a pizza or something [​IMG] ). I'll probably do the BFG Mud Terrains.
    BTW, I heard that during the blizzard of '96, before I moved here, the only way to get out was a guy with a Chevy truck with 44" Super Swampers on it who played snow taxi for everyone on the road. About 11" more than I had in mind, but pretty cool just the same.
  11. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I have to agree, the General AP's are good in wet stuff (okay, we don't have any snow here, but they're good in rain and wet dirt/light mud)
    I would think this is another one of those "it depends" questions, but my final vote is going to go with Swampers with siping in the center.
    My reasoning is that you mentioned that 4x4's even can have trouble on your road so it sounds like you need an extreme purpose-type tire.
    But really, any soft compound tire should work well, esp with added siping. And yes, lower your tire pressure, most wheeling can be improved with lower pressures.
    Lift It, Lock It, LIVE IT!!!
  12. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I used the AP's for several winters' worth of playing in the mountains, and loved them. The only time they ever gave me trouble was when summer rolled around, and it was time to play in the sand - the tiniest things would put holes in the tread (barbed wire for example).
    Dos mas Tecates!!!
  13. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    I Had some Marshal Powerguard mts and they were perfect for an alaskan winter and summer I havent got stuck yet and they worked pretty good in the snow and ice.
    1985 GMC JIMMY
  14. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    My set of BFG mud terrains did pretty well in snow. But they are really terrible in ice. TERRIBLE!! It's not a fault of the tire, mud tires just suck on ice. For a nice compromise of deep snow and ice capability I'd get some pro comp muds, (which are siped a bit from the factory) and screw some studs into them. That way you get a tire that can move some snow but also grab the ice.
  15. scrapmetal
    scrapmetal 1/2 ton status
    Jan 22, 2001
    100
    Rathdrum ,ID
    SUPER SWAMPERS SIPED GOOD, SNOW FUN,,,SUPER SWAMPERS BALD, SNOW BAD,,
    Never been stuck, just temporarily delayed.
    <a target="_blank" href=http://hometown.aol.com/bcscrapper/myhomepage/index.html>hometown.aol.com/bcscrapper/myhomepage/index.html</a>
  16. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    I'm running Dueler ATs and as you can see in my photo album below(snow pics), I didn't have any trouble negotiating 28" of the white stuff...........
    <font color=red>PHOTO ALBUM-</font color=red> <a target="_blank" href=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</a>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  17. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    I'll say one thing to start off: "Nothing sticks to ice"!!!! [​IMG] Sorry to Michelin, Goodyear, BFG &amp; anyone else who'd like to think they do but rubber doesn't stick to ice!! Sure some compounds of rubber do better than others but none stick! Now that that is out of the way; my advice is to get a mud tire which will do better in deep snow than an all-terrain &amp; have awesome off-road capability when the snow goes. I took a "sorta compromise" &amp; bought Super Swamper SSR's! Mud tire with some siping! [​IMG][​IMG]
    Good Luck
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  18. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Does any tire really do much on ice... HECK NO! Unless you have chains or studs most tiire are helpless on ice.
    I got Pro Comp MT's because of the sipping so we will see how they do. The sipping usually is more for wet pavement and water I believe. I think when you are in snow though they will get kinda clogged up.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  19. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    You're probably right about the aggressive sidewall. Snow ain't so bad, its the ice that sucks and siping is about all that helps on ice.
    John
  20. J.C.Staley
    J.C.Staley Registered Member
    Sep 23, 2000
    71
    Utah
    My 2 cents worth. I spend a lot of time in the snow between Northern Utah and Western Wyoming. The past 2 years I've been running Kelly Safaris in 33x9.5x15 and have been impressed so far. One trip to Wyo. we were cutting drifted roads and I like the narrow tires because the actually cut through the drifts. I've seen too many guys detained by running wider tires that carried them on top of the drifts but only so far. When they broke through they were suddenly resting on the snow with the tires touching nothing solid. I prefer contact with solid ground as much as possible. I'm getting old enough that shovel time is not as much fun as it used to be.
