Best Tool for Cutting Fenders
Discussion in 'The Garage' started by lak2004, Feb 24, 2007.
Best tool to cut fenders?
  1. Air Saw
    7 vote(s)
    20.0%
  2. Grinder
    16 vote(s)
    45.7%
  3. Sawzall
    6 vote(s)
    17.1%
  4. Nekkid with a razor blade
    3 vote(s)
    8.6%
  5. Other
    3 vote(s)
    8.6%
  1. lak2004
    lak2004 1/2 ton status
    Aug 31, 2006
    3,809
    Durango, CO
    Ok so I own an air saw and a Makita 4" grinder, would those be ok to cut my fenders with or should I get a SAWZALL? I am only cutting enough to clear 37's for now with a 6" lift.
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,852
    280
    Truckee, CA
    Sawzall is about the last thing you want to use, it will vibrate the hell out of the panel, bend it, and make a ****ty cut. It will look like you did it wiht your eyes closed.
    As for what to use, i can't make any reccomendations.....wait for experienced ppl to post up. Either of those should work though, air saw with a really fine blade.
  3. ivie29
    ivie29 1/2 ton status
    Apr 26, 2006
    212
    gypsum, colorado
    I've always used a sawzall and never had any problems.An air saw would work good on areas that are not double layered.
  4. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Cut off wheel on a grinder is the cleanest and easiest imo. Got to work hard on the bottom lip of the fender, but nothing a little time and patience cant get through.
    6" 38's
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Yep, use a grinder. It will eat cutoff blades so get a few.
  6. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Yep, X3
  7. jk5blazer
    jk5blazer 1/2 ton status
    Jan 28, 2005
    306
    Braselton, Ga
    Sawzall all the way. i didn't have any of the above issues. Mine turned out great, if I do say so my-self.
  8. greyhoundjc
    greyhoundjc 1/2 ton status
    Jan 23, 2005
    127
    Georgia
    I used an air powered cut off wheel and it worked great. I'm sure a grinder with a cut off blade would work too, just maybe a little more cumbersome.
  9. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    cut off wheel on a grinder. the way the wheel is in relationship to the tool makes it easier to handle then an air powered cut off tool.
    But if you had a plasma and skill that would be the way to do it.
  10. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    x4:D
  11. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    want a laugh??? i used a circelar saw with masonary blades.:haha: :haha: :haha: fast as hell.it was all i had and it was to cut the rear fenders shorter.:laugh:
  12. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Air body saw.
    They are easy to cut with.
    You can actually cut a straight line.
    No heat buildup to melt what's left of the paint.
    Cutting sheet metal is what they are made for.
  13. dhcomp
    Mar 17, 2001
    9,852
    280
    Truckee, CA
    those look sweet dpi, i like the finished look with the new trim!
  14. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Where is the chainsaw option. In a pinch, a hacksaw and a pair of pliers will get you by.
  15. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I used tin snips once when I was in a real bind(too big a tire, no more cash and new to an area). This was on my old Isuzu P'up though.
  16. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I used an air cut off tool. Very nice and smooth. Use a template and sharpie marker and then cut on the line.
  17. lak2004
    Aug 31, 2006
    3,809
    Durango, CO
    Cool sounds like I will be using my reciprocating air saw. But it wont be for a few more months.
