Best Tranny for all around use.
Discussion in 'The Garage' started by mud hungry, Nov 30, 2005.
What is the best and why?
  1. th400
    72 vote(s)
    30.4%
  2. th350
    42 vote(s)
    17.7%
  3. sm465
    69 vote(s)
    29.1%
  4. nv4500
    54 vote(s)
    22.8%
  1. mud hungry
    mud hungry 1/2 ton status
    Oct 4, 2004
    506
    Haydenville, Massachusetts
    Hey guys what is the best tranny for all around use. Meaning Daily Driver, mud, Trail riding,and hardly any amount of large rock crowling. and why?
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    well built th350 is good tranny. if you like auto.
  3. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    tis a matter of opinion... the consensus will probably be the 700r4 because of overdrive, excellent for street use... If you want a bullet proof auto tranny, the th400 is hard to beat. sm465 would be sweet, I would love to have a manual tranny in my truck.... but yeah its mostly opinnion, you should have made it a poll :wink1:
    James
    EDIT: woops, I didn't see the poll part, I must be getting sleepy.
  4. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    700R4. low first for crawl and overdrive for DD use.
  5. S. Burnham
    S. Burnham Registered Member
    Dec 12, 2004
    64
    hattiesburg, ms
    have you considered a 4l80e. there are companies out their making vacume shift module for these trans now for about $150. the 4l80e is a tubo 400 with an overdrive. I had some transmission sites pulled up that claimed the 4l80e trans was good for 4oo hp stock. If I ever get the chance to get one at a good price I believe that is what I am going with.
  6. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Yep!
    4l80e is interesting too though I don't know anything about it.
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    700r4
    x 3.7219
  8. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    700R4
    it has a good 1st gear and the overdrive makes all the difference on the road havin the overdrive you can run lower axle ratios and still dd it
    if you are making a lot of power then the 4L80E is a good opiton and you can get it setup to work without a computer
    but as far as the options you have in the poll then id go with the sm465 since none have overdrive you can go with a higher axle ratio for the street and have the low gear in the tranny make up for it on the trail
  9. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    a 465 as long as you can wheel a stick :D
  10. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    all the 1st gear in the world doesn't make the 700 as beat-the-snot-out-of-it tough as the TH400. :thumb:
    j
  11. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    We don't get the NV5600 option? Hehehehe..........
  12. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    465 just cause I like a stick and they are about bullet proof
  13. darenofears
    darenofears Registered Member
    Jan 25, 2005
    47
    Indiana
    sm465, its indestructible
  14. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I voted NV4500 cause it has a ubber low 1st plus overdrive. I also THINK that it is as strong as the SM465. No proof just what I think. Plus they use an internal slave cylinder on the newer ones->less stuff haning out to hangup on or break.
    Ira
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I like my 700r4 . Been DD for multiple years , been wheeled on OFTEN , driven to Moab and back . Either somone rebuilt it before I bought it , or I just have a well maintained tranny . Just have a nice sized cooler on it .
  16. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    Sm465
    X 6.55
  17. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    sm465,just because...:wink1:
  18. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    700r4 for overdrive or 4L80E
  19. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    NV4500
    6.34:1 first, .73:1 5th, and totally bullet proof.
    Its the SM465 first, 700r4 overdrive, and TH400 / SM465 in strength!
    If you can shift a standard tranny, there is no other way to go as far as I am concerned!
  20. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    700R4. but i will be swapping in the 465 just because i like standard trannys better. the 700 is preety good IMO.
