best tranny for mud???
Discussion in 'The Garage' started by chevy wrangler, Jul 30, 2006.
  1. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    whats the best tranny for mud bogging???:confused::confused: well i dunno what 2 get for my blazer, its gonna be mostly drivin in mud!:D
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Some sort of an auto I would think, cause you can get the goo in the clutches
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    with a manual it would be hard to shift and keep goin without losing momenteum. with an auto you jus romp it and hold on
  4. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    so would a 350 trans work?? thats what it has now, but now t-case
  5. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I would go 350 or 400
    Just cuz you can put your foot in it and have to let off for it to shift gears.
    350 would work as long as your not worried about tearing it up with a big motor.
  6. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    any of the chevy t-cases will work fine for a mud truck
  7. aknight_sa
    aknight_sa 1/2 ton status
    Oct 14, 2005
    305
    Saudi Arabia
    i would say stick with your th350 it is a strong transmission.. but what you need to do is to ensure that it wont everheat.. so change the transmission oil pan to a bigger one (if you still have the stock pan) and install a seperate radiator for the transmission fluid that is equipped with an electrical fan!!
    that way you wont have to worry a bit about your transmission...
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    ...and a trans temperature gauge would help you out also.
  9. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    ha yeah whatever you do stay away from a stock 700r4, id say a th400 would be the best. but either way, get the biggest tranny cooler you can find
  10. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    4 speed baby...when you need some quick power, just dump the clutch and away you go.
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    depends... if you're keeping it light, since it is a mud only truck, i'd go with the TH 350. if you're going heavy (big tires, 1 tons, full accessories, etc) then go 400.
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    WHOA! hold the train smokey!
    before you go worrying about swapping trannys, get the blocks out of the front before you hurt yourself, or worse yet, an innocent bystander.
  13. divorced
    Jul 20, 2004
    5,115
    uh, ya. You may want to get the blocks out of the front. You'll get beat up pretty bad on the forums for having them... if you live that long.
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    at least he put that as his worst mod, he knows its bad. the scary part is that he hasnt changed it yet
  15. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    well im not gonna go 2 big probly the same 350 but ima built it up and a dana 44 and probly switch that 12 bolt for a 14 boltff, i dunno what t-case 2 choose, that would be good for the goo??LOL
  16. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Stick Shift for Mud.
  17. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    A th350 should be fine if that's what you got I would run it.. A 208 or 205 will work and I would also run which ever one you got :D
  18. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    It's just mud. Run what ya got. When it breaks, replace it with what you had. If it happens again, think of upgrading....
  19. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    556
    Wasilla AK,
    4 speed all the way there tougher and instant wheel speed can be had auto's don't last in deep mud Especially th350's they suck why they put them in 3/4 ton pickups is beyond me . if you must run an auto save yourself the hassle and get a built up TH400 it'll save you money and hassle in the long run
  20. yellowK20
    Dec 26, 2002
    7,603
    556
    Wasilla AK,
    Also were gonna start having Muddboggs at my house about once a month here very soon your more than welcome to attend
