best tranny
Discussion in 'The Garage' started by geeman, Mar 13, 2007.
  1. geeman
    geeman Registered Member
    Mar 13, 2007
    5
    l.a
    i have a 1974 chevy pick up on 38's. i have a 350 v8 it came with a 700 tranny and a np241 transfer. my question is would a th350 tranny work better? any info would be helpfull
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    If you are staying with an automatic, stay with the 700r4, lower first gear and overdrive.
  3. geeman
    Mar 13, 2007
    5
    l.a
    yeah im staying with automatic
  4. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    yeah, keep the 700r4. If you are worried about it, you can get em built up a bit. Th350s are a bit stronger, but not enough to warrant changing em out, in my opinion
  5. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    keep what you have, you will never regret that overdrive.
  6. geeman
    Mar 13, 2007
    5
    l.a
    oh ok. i have 38's what gear ratio would be good?
  7. 454k30
    Sep 13, 2004
    1,613
    California, MD
    this is an eternal question that has been asked a lot! There really is no right or wrong answer, more of a preference really. Since my truck sees a lot of highway miles going to and from trails I kept the stock 4.10 gearing. With 37in tires this puts me short of 3000rpm at 60mph. I do not have overdrive and the engine seems pretty happy cruising at this rpm. I can tell you that when the day comes that this truck becomes a truggy that 5.13's or higher will fill both diffs because the crawl ratio will become much more important than the MPG.
  8. Russell
    Jun 23, 2000
    7,925
    337
    General idea is to get your rpms around 2000 - 2400 at 60 mph. Unfortunately, without overdrive that can make your truck a real slug off the line... You'd be able to get away with 4.56, but I'd reccomend the step up to 4.88 or 5.13
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive got a deep overdrive, run 5.13s. i ran 5.13s with 39.5's and i loved it with 700r4
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    if you plan on driving on the street: keep the th700.
    when your rig becomes offroad-only: th400.
    OD is cool to have on the highway, but really isn't worth jack offroad... and the th400 is much more durable.
    j
  11. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    4.88's if your on 1/2 ton axles
  12. geeman
    Mar 13, 2007
    5
    l.a
    so if i change my gear ratio in one differential i have to change it on the other one? im i right or wrong?
  13. resurrected_jimmy
    May 23, 2005
    2,241
    have to do both diffs. Not changing gears in the front = broken parts
