Best U-Joint (All opinions wanted please)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Feb 6, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    What's the best U-Joint to put in the rear/front driveshafts??? In my case it's be for a 12 bolt...
    Just wanna know what to buy.. doin preventative maintenance...
    Um... yes officer I know it's too big...
  2. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    Dana Spicer. You can get them at your local Napa Auto Parts store.
    [​IMG] [​IMG]
  3. loudandproud
    loudandproud 1/2 ton status
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    Spicer
    DOOH!![​IMG]<A target="_blank" HREF=http://loudandproud.coloradok5.com>http://loudandproud.coloradok5.com</A>
  4. northgate
    northgate Registered Member
    Sep 29, 2000
    75
    Sisters, Oregon
    Spicer. They're way more expensive, but they'll last a long time. Make sure you all the bearing caps have grease in them before you install them. Sometimes grease doesn't distribute evenly to each cap through the zerk.
  5. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    The best won i've found is Brute Force. I have a 6.2 diesel in my Blazer and have twisted 3 u-joints in half like paper under high torque. Have never broke a Brute Force and I get them at Autozone. Plus they have red seals which match my bushings.
    82 Blazer
  6. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Spicer above all..!
    Can also get them at the GM dealer
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Listen to the people. Kinda wish the government would do the same thing! Yeah, stick with Spicer. You are paying for what you get, and that is quality!
  8. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    Neapco joints are right up there with Spicer. I like them better because they have alot nicer machine work done to them. Look at a Spicer and see where the dust seal is. The spicer joints are justed turned in. They have deep grooves and machining marks. The Neapco joints are grounded all the way thru. By the way Neapco makes Brute Force.
    Donovan
    <A target="_blank" HREF=http://www.rustbucket.coloradok5.com>http://www.rustbucket.coloradok5.com</A>
    Bigger is Better
  9. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    oem snap joints are the best-spicer no zerts-
  10. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    I would have to say Neapco Brute Force, then Spicer, the Neapco's have lasted much longer in the same spot than the Spicer's I have tried.
    One of the guys in my club buys Ujoints from out west, he has to get me the name, but I have seen him wheel and he has been on the same FRONT AXLE joints in a Dana 44 for over 10 years. The rig is a hybrid he build, the frame is half Early Bronco half Bronco II with a cut down Bronco II body. It has a Dana 44 front and Dana 60 rear and a friggen Nascar 351 under the hood that is PURE POWER. He runs 36" boggers and has snapped a rear axle shaft twice.
    The ujoints are NOT CROSSDRILLED, they are solid, each cap has a needle type grease fitting to grease them. Its a PITA sometimes, but he has not had one fail and he is hard on the rig, it has been driven to MOAB wheeled and driven back to Atlanta GA 4 times, not to mention Tellico and all the wheeling he does here.
    Depdog
    <font color=blue>Weenie K5, little mods' Small Tires!</font color=blue>
    <A target="_blank" HREF=http://depdogsk5.coloradok5.com>http://depdogsk5.coloradok5.com</A>
  11. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    Hey Depdog, I'm out west and would like to find out more about the u-joints you describe. Drilled greasable joints are weaker, but the bearings in solid, non-greaseable's don't last as long. Non-drilled greaseables sound like the best of both worlds. Greasing each cap sounds like a PITA but not as much as replacing a broken joint on the trail. If you get me a source, I'll put'em in my truck for a product test. Thanks.
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  12. Donovan
    524
    Arvada, CO
    Look at the June 1999 FourWheeler magizine and they have all the tests on breaking u-joints and which are best. They said and the data shows that the greasable joints are not that much weaker. In fact the Dutchman greasable was stronger than there none greasable ones. Larger dana 44 u-joints are in the works as we speak.
    Donovan
    Bigger is Better
  13. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Drivelineman please explain
  14. dyeager535
    26,979
    Does Spicer make the "adapter" u-joints? Got a 10 bolt in my K5, with a u-joint from a '76 Blazer 12 bolt.
    Dorian
  15. Executioner
    Feb 22, 2000
    1,530
    Yes, they do !
    Sorry I don't have the p/n on me.
  16. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    The Napa 447 conversion U-joint works on mine. Don't know if it is made by spicer or not.
