best undercoating remover?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yunit, Oct 8, 2001.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Got to remove the undercoating on my floor pan. What is the best stuff to use for this? I need something that will remove it with the least amount of work. Thanks.
    1987 Jimmy Sierra Classic, Palisades Park, NJ 07650
  2. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    Is the floor pan in or out of the truck, if it is out, I would think sand blasting would be the best and quickest way.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
    <a target="_blank" href=http://www.bens87toy.alloffroad.com>www.bens87toy.alloffroad.com</a>
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    ATF works well. It will dissolve that stuff pretty good.
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    Light the rig on fire and wait for it to burn off...[​IMG]
    Actually a heat gun and a sharp flexible scraper would prolly be the easiest...still a huge PITA though.
    Rene
  5. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Wurth is a German company that distributes automotive tools and supplies. They have a air tool called a MBX Metal Blaster that uses wire wheel belts and if you use the most aggressive wire belt you can remove all of the tar/undercoat stuff from the entire floor in 2 hours. I did mine that way. The thing works better than anything I have ever seen but it is very expensive. I called the area representitive from Wurth and had him loan me his sample tool to try out. After I was done I just reurned it for a "no charge". You might want to find your area rep because this thing is a real time saver.
    Wurth phone number is 1-800-987-8487
    <font color=red> Bill, "Shop Rat" </font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/Shop-Rat>http://coloradok5.com/gallery/Shop-Rat</a>
  6. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Eastwood makes a chemical that your spray on you can just scrape it right off. http://www.geocities.com/bigkern76
