Best Water Pump?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric78K5, Jul 17, 2000.
  1. Eric78K5
    Eric78K5 1/2 ton status
    Feb 18, 2000
    230
    South Carolina
    Well, I want to start buying some new pieces before I have the new 350 installed. I want a new pump, cause I'm getting a new radiator, so I want suggestions. Pros and cons would be helpful also. Thanks.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I am running the Summit Hi-Flow pump.
    It looks stock but has a higher flow rating and is said to eleminate the air pockets or hot spots that can occur in the blocks water chanels. My rig runs at 185 hwy and 185-190 in town.
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  3. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    I get mine from pep boys. They are new and have a lifetime warranty.
  5. Eric78K5
    Feb 18, 2000
    230
    South Carolina
    How about the Edlebrock pumps? If I decide to add a little shine under the hood, I may try one of their chrome/polished ones. Anyone out there using one of these?
  6. Burt4x4
    6,854
    Just remember chrome retains heat and heat kills bearings/seals etc.....[​IMG]
    So if I wanted to preety it up I would go with polished aluminum, but of corse thats usually high$$$$...........
  7. JimmyDie6.2
    Jun 20, 2000
    453
    Long Island
    I have a chrome water pump on my GTO, you have to clean it all the time or it will start to flake and look like junkyard crapola.
  8. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I have a OEM replacement that is plain old black and I have no complaints. It was cheap too, I think when you see an add in the paper that says "water pumps starting at 39.99" the 39.99 in all cases is a SBC...I love My mouse
  9. Peeetah
    Peeetah Registered Member
    Jul 3, 2000
    97
    Mt. View, CA
    Go to Napa, Pepboys, etc, etc, no need to pay so much for and have to wait from a hi per. pump from summit. Just make sure it is a BRAND NEW pump no a remanufactured one. Rebuilt is ok for alot of truck parts but water pumps should be brand new.
  10. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    I've got a Howard Stewart hi- flow and it works great ! I'd highly recommend one.
    L8r,
    .Riz.
