Best way to adjust valve lash...the non engine running method isnt working
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90idahoblazer, May 28, 2002.
  1. 90idahoblazer
    90idahoblazer 1/2 ton status
    Jun 24, 2001
    183
    Idaho
    I have tried the chiltons method...runs rough....should I adjust both banks?....How about the engine running method with hydraulic lifters...There was only a slight clatter before I messed with the perfectly good motor....That will teach me to leave well enough alone
    Thanks guys
  2. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    Come On out of all you Mechanics...no one has any Ideas on how to adjust valve lash...
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    When I did mine I had the motor running, (at operating temp) and backed them off till they made noise. Then tightened them up till it stopped chattering, and went an extra 1/2 -3/4 turn after they were quiet. I need to do it again as a matter of fact. Its messy tho, oil spruts out the top of the rockers when running.
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The engine running method is really the best. You will want to do both sides. Use pieces of cardboard to try to help with the oil spray and good luck. Where at in Idaho are you?
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I was trying to find a post from a year or so ago on a newsgroup. But anyhow, the procedure best to use is a degree wheel and you start at TDC, adjust those, turn so many degree's until the next one in firing order, adjust those...as so on. I struggled with the same thing a year or so ago, the engine running method really bites, not to mention no factory or engine shop I've been to adjusts them with the engine running. I used the degree wheel and it worked perfect the first time, and no mess! Just wish I could find my instructions.!
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I'm partial to the motor off way. The oil spurting everywhere method sucks. I also it really isn't as accurate as other methods out there. Most people use the 1-6 method... adjusting the rockers while the motor is in either #1 or #6 position. I assume this is the method you were using... I have had best luck adjusting to zero lash and half to one additional turn
  7. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I use the motor running method. It's quick and the adjustments match to your lifters bleed rate which can additianally identify worn lifters early on. 1/2 to 3/4 turn past chatter should do you fine,I'm not convinced on the 'steeling lift' at higher RPM through some tightening methods although I have seen compelling evidence to support it at the track. They sell clips at your local parts counter to snap on the valves so they cant squirt while you do it, a flat surface helps to control drippage depending on the heads your running, camel humps leak no matter what!
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've had good luck doing the motor off method if the cam is not to wild. The last cam I installed had a .488 lift and the motor off method did not completely work out. It also depends on who you talk to. Try the motor off method first (its cleaner), and if it doesnt work, finish it up while its running.
  9. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    Thanks guys...I used the off method and went 1/2 turn further...now the engine wont start...so I bought those clips and Im going to do it with the engine on....I will let you know how it works...
  10. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Get a old set of steel valve cover and cut a slot in the top of them to make your adjustment thru. Put a rubber gasket on it so it's reuseable. If you do one side at a time then you only need one cut down cover. Also use the clips at the same time. The cut down cove solves the leak back problem.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Loosen them. Keep in mind that too loose is much better than too tight. You don't want to burn a valve.
  12. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I had a problem doing it with the motor off before too. What I was doing was tightening until I could no longer turn the pushrod with my fingers and then tightening another 1/2 turn. What I was inadvertantly doing was going well beyond zero lash before adding my 1/2 turn.
    I backed em all off again and then snugged the rocker nuts until I had no more up and down play at the pushrod and then did my 1/2 turn...that worked much better. I'd guess you have em way too tight right now.
    Rene
  13. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    Awesome Guys....Thanks
  14. dogman
    dogman 1/2 ton status
    Oct 31, 2001
    213
    California, Santa Clara Co.
    I usually use the engine off method with very good results. it works everytime I'v done it on 265,283,327,350,400.
    for hydraulic lifters: back them off loose. I tighten until the push rod makes contact.
    by spinning the push rod, feel that the lash is gone, that is no more movement up and down.
    I turn, 1 full turn down. <& that's right out of the Chevy motor manual.
    to set the push rod half way into the hydraulic lifter. (with a fresh motor I fill the lifters with oil from a squirt can)
    make sure you count #1 front drivers side, #2 is front passage side.
    won't start?
    did you put you timing mark on one, is the rotor pointing at the cap #1? and not a tooth off??
  15. Jay73K20
    Jay73K20 Registered Member
    Mar 4, 2002
    67
    I'm suprised no one is mentioning high pump lifters.
  16. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Valve covers with holes in them .. now why didn't I think of that! Nice trick, I like that one
  17. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
