Best way to do steering???
Discussion in 'The Garage' started by camok5, Feb 21, 2004.
  1. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I just finished putting my 1 tons on and a 6inch lift using custom Deaver springs. My problem now is that the blazer is my daily driver and the springs are to soft to remove the swaybar for crossover steering. I put a spacer block to help level the steering but it is still to much of an angle. I dont want to use a drop drag link because I have bent them before when jumping. Any sugestions on a better way??? /forums/images/graemlins/thinking.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Drop pitman arm?
  3. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    any idea on who makes the best one...
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    adjustable shocks and crossover.
    or dual shocks for the road remove one for the trail
    grant
  5. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I have rancho 9000s but these springs are REALLY soft.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The best thing is to sell that block and order a Sky manufacturing crossover steering kit for $319 to your door.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    are you getting a cut from sky the way you push that around here? His springs are too soft to lose the swaybar. As I see it the only option to go with crossovoer would be some custom sway bar setup.
  8. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I looked at doing a custom swaybar and its more trouble then its worth.
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i would look into a second set of shocks then. mount them with hich pins top and bottom. make them a bit shorte on the down stroke so as to use the internal bumps ad down restrictors. then the up leave enough room for them to fully compress if needed along with the other shocks. use the least expensive toughest shocks you can find. then you wont have any problems. by limiting the down stroke it will act a bit like a sway bar.
    id look for some stock replacement monroes for a 1 ton or so.
    Grant
