Best way to drill through carpet?
Discussion in 'The Garage' started by y5mgisi, Jan 28, 2005.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Im laying down some new carpet in the burb and i ned to drill holesthrough the carpet and floor to put the trim screws back in. Is there a good way to do it? Ive actually broke two drill bits now cause the carpet catches so bad. any ideas?
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    hiw about an awl?
    just poke through and raem to your liking?
  3. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    sorry man but what is an awl? the thing is is not only do i need to go through the carpet i need to drill through the floor too.
  4. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    An awl is like a real heavy duty needle, used for sewing and punching leather and heavy fabic. they usually have a lame on on the back of most swiss army knives, but you can buy a good one at a hobby store for a few bucks.
    If it's going under a trim piece I would just cut a little slit with an x-acto knife, then drill.
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    if your using good sheetmetal screws just put them in no need for a hole, they will go through
  6. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    an awl is a punch generally used for poking holes in tough materials such as leather or carpet in your case.
    i would suggest leaving all the bolts in their respective holes but sticking out at least a quarter of an inch. then when you lay the carpet down, take a utility knife and cut an x over the bolt/screw head and pop the head through. then you don't have to worry about finding all the holes, they will be easy to find.
    good luck:grin:
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    It may sound silly, and depends on the carpet you are using, but burn it (the carpet) where you want to drill. If you smoke, it should be easy. Be careful not to make too large a burned spot, just enough to keep the carpet from catching on the drill bit.
  8. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    sweet. Thanks for the replys Im pretty sure a have an awl laying around now that youv desribed it to me. Any who thanks again time to get back to the drill.:cool1:
  9. Quaddawg
    Quaddawg 1/2 ton status
    Dec 15, 2004
    113
    Cincinnati
    Believe it or not, I use an old soldering iron to "cauterize" a small hole where I want to drill, that seals the carpet and keeps it from fraying, and catching on the drill bit too.
  10. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Here's what I did. Installed the screws where they had to go. Lay the new carpet over the screw heads,and took a razor blade and cut an X over the bolt head. Worked great. Have fun
  11. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    This is the same thing but a different way of doing it. put some masking tape over the carpet where you want to drill the hole. Mark said hole with a pen. Cut out the hole where the bolt goes with the razor blade. Drill hole with the tape still over non-cut area. Then pull off excess tape. All done.:)
  12. RustyMule
    RustyMule Registered Member
    Dec 18, 2004
    73
    Westford, MA
    I've seen a "cheap trick" in four-wheeler magazine about this. I think they said to put a socket over the hole area, put some pressure on it, then drill right through to hole in the socket. I have NO idea if it works becase I've never tried it. Feel free to correct me.
  13. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,961
    251
    Released from Pueblo, told I belong in Southpark
    I have heard of people using a shell casing from a bullet and hit it with a hammer to make the hole. .22 for small hole well you get the idea.
  14. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Just use live rounds and save time and effort of drilling! :eek1: :eek1: :eek1:
  15. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I use the soldering iron too. Makes a nice, clean hole but you need to watch those fumes.....
  16. idf_johnny
    idf_johnny Registered Member
    Nov 4, 2003
    14
    Elk Grove CA
    If you are using self drilling screw just spin the screw in reverse to get through the carpet, once you hit metal switch the direction on the drill and installl the screw. should work the same with a drill bit. another trick if you need to do a large hole saw size in a trim panel or carpet, run the saw in reverse to wear through the material. the teeth wont be grabby in reverse.
  17. diesel4me
    Jul 24, 2003
    17,561
    940
    Massachussetts
    Huh???
    Carpet???? whats a carpet?????--you mean a RUG??---in a 4x4 ???:what: :dunno: :haha: :haha: :haha:
    Sorry-most of my trucks have had bare steel floors!! A rug only traps water and salt from your shoes,and rots the floor out in record time--and it makes it hard to hose out at the car wash!--my 82 K20 and 79 C10 still have the rugs,but they arent in great shape,being original...
    I have twisted my share of carpet around drill bits and self-drilling sheet metal screws too,I have no easy answer for you,but I did read of a trick in one book ,they say if you put elmers glue on the spot you want to drill and let it dry,then you can drill it with no unraveling--never tried it myself,I usually remove the rug,drill the holes,and put back whats left of it(it usually is in tatters by the time I bought the truck!!)..:crazy:
  18. 70jimmy
    Mar 3, 2000
    5,961
    251
    Live rounds work too you just have to be a good shot and chase the dog out from underneath the truck before you shoot. Watch what is behind your shot I wouldn't want to do a live test to see if the 205 is actually bulletproof.:mad:
