Best way to fix leaking slip yoke plug?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Dec 5, 2003.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    The plug in my slip yoke is leaking, what is the best way to fix it. I have been thinking about just welding the SOB.
  2. bckinblk
    bckinblk 1/2 ton status
    Jun 12, 2002
    305
    bristol connecticut
    Mine was leaking in the yoke itself .I used ge industrial silicone and stuffed it there and it has'nt leaked since about $5 a tube at any hardware store .Also the 208's are notorious for leaking right at the output seal .Make sure you check that when you pull the slip yoke out ..Good luck. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I second the silicone trick. My buddy with a driveline shop says that is all he ever does.
  4. bajaviking
    Apr 10, 2002
    752
    Baja
    The output seal is completely dry and the u-joint is soaked in ATF so I'm pretty sure it's the plug. I will try the silicone, sounds cheap and easy, cheap and easy is my favorite way to fix stuff /forums/images/graemlins/thumb.gif
  5. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    I had the same problem... I first cleaned it with a little brake clean and a toothbrush. then filled it with silcone. No leak. Its been about 6 months. /forums/images/graemlins/thumb.gif
