best way to gain a few more inches
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Oct 9, 2001.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    What is the best way to add on a few more inches, when you already have an 8 inch lift. No body lift. I am thinking about a nice set of shackles. Dont really want add-a-leafs, but I might have to. Any more suggestions?
    Ken H.
    '78 K5 in process
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    A body lift is the cheapest, but can be a real pain to install. Ill probably add a 2-3 inch BL pretty quick.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  3. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    cut those fenders!!!
    Sherman, Tx
    <font color=red>The blazer's almost on the road....anyone got tree fiddy?</font color=red>
  4. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I am not real concerned with the cheapest route.
    I would rather not go the direction of a body lift. I think I mentioned that in the oringinal post.
    Ken H.
    '78 K5 in process
  5. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Well, originall I Was going to hack and whack the fenders on the Blazer. Now I may have gotten a differant one, with a much nicer body. And I would rather not hack a nice body up.
    Ken H.
    '78 K5 in process
  6. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    body lifts are great
    way easier to clean the under side
    even though my truck has way too much lift i wont give up the bodylift, i would change out the springs in a heartbeat though.
    i have the same 2" BL that was on the truck in 1990 when i bought it, zero trouble.
    no way are you goona gain "couple inches" safely with a mere shackle swap
    you would have to build drop brackets for the front hanger(ugly)
    new springs or a BL
  7. laketex
    6,220
    North Texas
    long shackles can get pretty squirrly. You said you wanted a few inches. Like 3?? That would require a 6" longer shackle, screw up your caster angles, your driveshaft angles, and probably wander all over the road.
    You could make custom spring perches in the rear for about 1" more lift. A 1" block in the rear?
    There's just not much you can safely do to the front besides new springs. Maybe lowered spring hangars?
    Sherman, Tx
  8. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    Here's what I did to get some extra lift out of the suspension:
    Lower your front spring hangers. Then use a longer shackle. 3 inch lower spring hanger and 3 inch longer shackle should offset each other if I do my math right. In the rear do the shackle flip from ORD or just cut the bottom out of your existing shackle hangers and drop the existing shackle down through the hole. This would give you abou 4 inches of lift in the rear.
    -Aaron
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  9. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Add-a-leaves aren't gonna work on an 8" spring.
    How is the rear lifted? Shackle flip in the rear may point the pinion up too high.
    Body lift is your best option. They're not that bad, really.
    Besides, you're not going to be able to do any of that other stuff for under $69.95!
    Still Poundin' "pavment" after all these years!!! [​IMG]
  10. RedDwarf
    May 9, 2001
    816
    Hey 77Chev, maybe you guys should swap springs?
  11. AGM73k5
    1,246
    Portland OREGON
    If the pinion is too high after the shackle flip then he could probably cut and rotate the spring perches until he got the angle he wanted :) If he's not prepared to do that, then you're right he may well run into trouble with pinion angles.
    -Aaron
    ___ __ _ _ ____ __
  12. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    There's an ad in the back of Penthouse.......
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah! It says only $9.95!
    Tim
  14. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Viagra!
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  15. 77Blazer
    77Blazer 1/2 ton status
    Aug 13, 2001
    197
    Long beach CA
    if you are really worried about those fenders just take it to a body shop to get it done.
    350, sm465, NP205, 14ff w/detroit, yucky ten bolt 4" springs,38.5x14.5 swampers
    <a target="_blank" href=http://www.planettribes.com/theden/gontw/nsig.jpg>http://www.planettribes.com/theden/gontw/nsig.jpg</a>
  16. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Usually...I like to fantasize about my sister-in-law. Always good for a few inches. LOL!!!
    9/11/01..Never forget...Never forgive
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    OUCH!!! Don't let your wife read THAT!!!
    Tim
