best way to get 8" Lift
Discussion in 'The Garage' started by George_Pimpdaddy, Dec 14, 2005.
  1. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    Hey was just looking up the wishlist and was wondering how you guys think that i should go for the 8" lift that i have decided on. I have a 89 Chevy Blazer rebuilt 350TBI 700R4 NP241 10bolts with an auburn posi in the rear. Now i like the idea of about a 37" tire probaly bfg mud terrains. I defenatly would rather not have blocks in the rear and am not to sure about body lifts. I also DD this truck and do alot of 4x4in in spare time, including hunting. Now i also have seen the shackle flip kits available for our trucks and dont mind the idea and like how it would probaly help with the rear driveshaft angle by pointing the pionion upwards. As for my springs i figured a all spring 8" BDS or pro comp lift would work along with the controlable rancho shocks that they have now with the control in the cab instead of on the shock body. Does this sound good so far?? would i need a new driveshaft? or could it be lengthened?
    eventually i see the truck with a 14 bolt in the rear also and custom made 4x4 bumpers front and rear with a receiver mounted warn winch.:bow:
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    That is a lot of lift for that small of a tire. If I were you, I would do a 6" TC spring in front, shackleflip the rear with the ORD one and get their extended shackle, and a 2" spring. You could also add in a zerorate front and rear if you needed the extra inch.
    BTW I am running a 4" TC spring and a zero rate, in the front, for a 40" tire. I may go to a 6" spring, if I HAVE to.
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    8" is alot of lift for a 37" tire. I would go 4" and fender trimming. Maybe add a Zero-Rate to lessen the amount of trimming if you care about your fenders that much. 8" is for 40"+ tires. I like the BFG M/T. But for 8" lift I would go 8" springs front and probly 4" rear springs and a shackle flip. If just doing 4" (much better ride and flex) I would suggest 4" front springs from say Superlift or BDS (my rough country's are a bit stiff) and if you have good rear springs just do a shackle flip. If they are tired some new rear springs. Also when you start lifting up to say 8"s your gonna want to look into crossover steering and the such. Many people here are running 40's with about 4-5" lift.
  4. 1-ton
    Apr 17, 2004
    2,890
    168
    Las Vegas, Nevada
    I am pretty sure that no company makes an 'all spring' 8" lift. If you read the small print details of the contents of every companies lift kit, most of their 8" lifts come with an 8" spring in the front, but have a 6" spring in the rear with a 2" block. A 4" shackle flip with a 4" rear spring, and 8" springs in the front would be a good way to go. I think an 8" lift with 37" tires would look OK, if you are going for the "Mall Cruiser" look, but if you don't want to go wheeling with a truck that handles like a PO-GO stick, the setup that the other guys mentioned would be the best solution. I also think thay 37" tires are a too much tire for a truck with 1/2 ton running gear, but it can be done if you really want to. I would recomend 33" tires with a 4" lift (or less) for your truck because of the current running gear you have.
  5. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Skyjacker lists an 8" kit with 8" rear springs. Kit # C180AKS. They have others with blocks or add-a-leaf. I dont like it that high because of easier to roll over being so top heavy. And definatelly upgrade those axles. I blew up a 12 bolt with 35's.
  6. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    6 in will fit a 37 with no/minimul trimming
    but for an 8 i would go with shackle flip in the rear and a 4 in spring
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive got BDS 8" springs front and rear. wish i had done 4" springs and shackle flip in rear. very pleased with BDS frotn shaft will work, but splines show, also hits y-pipe. rear shaft works when lengthened, but gives vibes. mine is a dd as well.
    check out bigcountryx, hes got a sweet k5 8" lift and 39.5's
  8. 1-ton
    Apr 17, 2004
    2,890
    168
    Las Vegas, Nevada
    BDS has a picture of their 8" suspension kit, and it looks like it has some blocks to me.
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    no sir, aint no blocks on my rig :-)
  10. TBair
    TBair Registered Member
    Dec 14, 2005
    12
    Grand Ledge, Michigan
    i also made the mistake of getting the 8" lift springs for the rear of my K10, i have no axle wrap at all but i also have no flex what so ever. on top of the the ride is horrible, it will bust your kidneys. if i could do it over id go shackle flip with a 2" spring and 4" blocks and some kind of 4 link or trac bars.
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    haha funny u should say it bust ur kidneys, i had kidney surgery last month hahahahah
  12. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i hae 8" rear springs too, i believe that they are superlifts.
  13. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    How do you figure? I had 9" with no trimming and my 35's still mashed the fenders.
    How about this:
    Front = 6" springs, extended shackles, 1" zero-rate
    Rear = 4" spring, shackle flip from www.diy4x.com, and a zero-rate if needed
    1" body lift if you need just a little more
    The front 6" springs will ride/flex better than 8" springs, you will need extended shackles so the springs don't hit the frame, and the zero-rate will give an inch of lift and move the axle forward some if you need to.
    :D
  14. TBair
    Dec 14, 2005
    12
    i beleive 6"/37s if you leave the sway bar in the front. buddy of mine runs 7"/38s and hasnt mashed his fenders. i took my sway bar out and 35s mashed mine all to hell.
  15. 1-ton
    Apr 17, 2004
    2,890
    168
    Las Vegas, Nevada
    This is close to the setup I am putting together for one of my 1-ton trucks right now (except I am going to use stock springs in the rear with a 3" block).
    My Truck
    Rear = stock spring, shackle flip, and a 3" block
    1" body lift
    I am thinking of going with a set of 36/14.50/16 tires with this lift..going for the Mall Cruiser look.
  16. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
    I have 8 inch front springs with the shackleflip/4 inch block combo on the rear and my 35s mash the front fenders. Looks okay how it is and contrary to most, it really isn't THAT top heavy. Look at all the Superduties running around with 20 inch lifts and no problems, I think that our trucks can handle 8 inch lifts. One thing I regret is buying Superlift springs, they are stiff as hell, saggy and just suck. I am switching to BDS next winter. Just my opinion though, I am not a hardcore crawler.
  17. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    i am doing a similar set up...
    the best thing i came up with is:
    front = 6" spring + 1" zero rate + 1" extended shackles = 8"
    rear= 4" shackle flip, 3" spring, 1" zerorate = 8"
    it all depends on how you want it to sit though, give or take an inch in the rear depending if you want it level, 'prerunned' or stinkbugged.
    37s will be fine, but you could fit 38s with a true 8" lift over stock.
  18. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if u want flexy 8" lift, do 4" lift 52's in front, shackle flip and 4" lift 56's in rear
