best way to get grease OUT of bearings??
Discussion in 'The Garage' started by 85mudblazin, Jan 11, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    The PO that had the 14bff installed new bearings but he packed them with grease, I have been told you dont need grease for the 14bff bearings since they get lubed with the gear lube, so what is the best way to get the grease out?? brake cleaner??
    -Chris
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    brakekleen, or if you have some diesel, try that.
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    leave it. they will be just fine. i pack mine with some grease when i reasembling mine.
  4. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    try varsol, it works fine for me!
  5. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i packed my bearings when i did my 14 bolt. is that bad?? im about to put the axles in!!!!
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Solvent! I know most of you dont have a solvent tank, but it is the easiest way!
  7. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Won't hurt it a bit.....:D
  8. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    we usually grease them as well. the fluid doesnt instantly get down the tube to the bearings so there dry for a little while till the fluid workse its way down there. i think any way.
  9. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    There is absolutely no need to pack the bearings with grease on an oil bath hub.
    All the grease does is make a gooy mess.
    Squirt some gear lube on the bearings and let it run through, install the hub and prefill it before installing the outer bearing.
    Assemble the hub and make sure the diff is full.
    If ya are that concerned raise one wheel at a time for a few minutes.
    The lube will drain into the hub and fill it.
    The gear lube in the diff suppies lube to the bearings.
    I have assembled thousands of hubs without packing the bearings with grease.
    Never had a problem.
    I generaly don't raise a wheel unless I get in a hurry and didn't prefill the hub before installing the outer bearing.
