best way to get out rubber spring eye bushings?
Discussion in 'The Garage' started by OffRoad, Mar 2, 2007.
  1. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    i'm swapping front leaves and i'm preparing the new ones now. they were cut out of the old truck with a torch. i'm down to the bolt and the rubber bushing. i don't have a torch. what should i do?:confused:
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Press them out.
  3. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    1. press.
    2. torch.
    3. drill-n-chunk method as shown in my 52" spring swap tech article.
    j
  4. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    it may take a bit longer, but it works because this is how we got the crusty old rubber bushings out of some 63s. go to walmart, buy a small propane torch and heat those mofos up and start taking pieces out with a flathead that you don't really need. worked for me and didn't require too much money or muscle.
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    $10 Propane torch from the hardware store works well.
    Put the spring in a vise sideways with the eye hole vertical and put a coffee can on the floor underneath it, torch them, the rubber will burn and drip out.
    Make sure everything around it is clear and you have adequete ventilation, as the flames can get high, and so can you if your not careful.
    Works well though.
    It's the only way the bushings from trucks here in MI come out. It's amazing what a little rust can do. When I first brought my 73 here from AZ, the bushings came out with a couple light taps of the hammer.
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    drill them out. run a decent sixe bit through in a couple of places. should chunk the rubber and make it easier to get it out. less risk of burning the garage down.
  7. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    What he said, oh ya have fun with the metal sleeve too:eek1: :haha: :haha:
  8. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    metal sleeve technique is shown in my tech article too...
    j
  9. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    I drilled them out
  10. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    I must not have read said thread. My hands hurt for 2 days after that, from trying to remove those da*n sleeves:eek1: :eek1:
  11. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    not a thread, a tech article... tech section. :)
    j
  12. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    If you decide to press them out I would still drill some holes through the bushing first.
    Its quick and easy and will save you a bunch of hassle on the press :D
  13. OffRoad
    Dec 8, 2002
    852
    thanks for the response guys. i'll prolly try the $10 torch method.
  14. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,235
    284
    San Jose, California
    A sawzall works too. Just cut a slice in the bushing (without touching the spring eye) and then hit it with a hammer a couple times.
  15. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I guess i'm spoiled. My 40 ton air over hydraulic press laughs at just about anything i throw in it. :D
