Best way to get Spring perches off a 14bff?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by slayer77, Oct 28, 2003.
  1. slayer77
    slayer77 Registered Member
    Oct 21, 2003
    29
    Pleasant Hill Ca.
    thanks in advance...
  2. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    Well, I used a 4 1/2 electric side grinder with cutting discs to get it off, then I used grinding discs to finish knocking it down, followed by a 60 grit "flapper" disc to polish and dress the metal.
    Just gota be careful not to go too deep when you start cutting at the axle tube.
    Just my .02
    Byron
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Grinder and cold chisel, works everytime....
  4. slayer77
    Oct 21, 2003
    29
    Pleasant Hill Ca.
    Right on!! Thanks for letting me know... Is there a place to buy new perches?
  5. rearsteer70k5
    rearsteer70k5 Registered Member
    Jun 28, 2003
    33
    newark,cal bay area
    moroso sells a set or vic hubberd in hayward also sells them. They all come in three inch axle tube dia. you just have to shave it a little.
    Rick
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    A little die grinder/cut off wheel action, and a BFH say a 5 pounder will knock em right off. /forums/images/graemlins/eek.gif
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Just don't have it up on jack stands and drop the thing on your pinky toe /forums/images/graemlins/1zhelp.gif...That hurt for a while
  8. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    is this what your looking for....
  9. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i cut my shock mounts off with a torch.then finished grinding them flat with a angle grinder.should be the same with a spring perch.
  10. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    I had Greg72 make me a set of new perches which had a 2 inch off set in them to move the axle back to the center of the wheel well. Look how axle wrap rounded off my old perches.
  11. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Hey..... I recognize THOSE!!! /forums/images/graemlins/thumb.gif
    Do you mean to tell me that you STILL haven't installed them yet????
    /forums/images/graemlins/grin.gif
  12. slayer77
    Oct 21, 2003
    29
    Pleasant Hill Ca.
    Yes... Right on! Where do I get them?
    Thank you
  13. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I made my perches for my 14B.
    I used some 2.5x2.5x.250 square tubing cut to about 7" long each. I then clamped them together and used a 3.5" hole saw to cut the arc in them. The hole saw would not go all the way through so I had to go at it from both sides. I than drilled 2 9/16" holes in the tops (one centered and one 1" forward to move the axle back 1"). After they were welded on I capped the ends with 1/8" steel plate and rounded off all the corners to make them look clean.
  14. SCJimmy
    Mar 7, 2003
    406
    Thank you
    Here
    They are $14.95 a Pair /forums/images/graemlins/eek.gif, and worked fine on my 14bff They are Dodge spring pads...
    Byron
  15. aksidentproan
    Dec 8, 2001
    477
    Maryland
    Actually I got them on early in the summer but I've been so busy with work and school I havent had much time. Now that winter is rolling around work has slowed down and I have more time on CK5. They really work great man. My axle is right where I want it and I have no more axle wrap. Thanks again for the perches. They were truly well made.
    Evan
