best way to get u joints out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wakedog, Nov 5, 2001.
  1. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    What is the best way to get the u joints out of the front axle shafts??
    <a target="_blank" href=http://www.bigredjimmy.iwarp.com>http://www.bigredjimmy.iwarp.com</a>
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I use 2 sockets that I don't use . one is just a tad smaller than the cap and the other is is a tad bigger on the inside than the cap.
    Then with a 4lb hammer I give it a few whacks and they usualy pop right out.
    Use emmory paper to clean up the shaft and always use never-seez on reassembly.
    It makes it so much easier to get it apart the next time.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  3. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    yeah hammers or a vice work fine unless you have an injected plastic type. On some models, Chevy cut a ring in the yoke and a corresponding one in the cup bearing, then filled it with molten plastic. This acts like a cir-clip that is more typically used. In order to get the injected plastics ones out you can a) melt it out with a torch or b) (I did this today) use an arbor press to exert 3 and a half tons of pressure on the cap to shear the plastic in half. After a loud *bang*, the u-joint falls right apart. The plastic sheared nicely in half and could remain in with the new clip style u-joints.
    Shutup Brain or I'll stab you with a Q-Tip - Homer J. Simpson
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I did my front axle u-joints. Mine were the clip type. I had to use a press, and when they came out, they nearly exploded out. They were 18 years old.
    Tim
  5. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    hammer, socket, and vice..
    [​IMG]Mash Out![​IMG]
    82 Blazer 1 Ton "Big Nasty"
    78 Jimmy 3/4 Ton
    <font color=red>"Red Dawg" </font color=red>
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've found that it's oten WAY more difficult to get u-joints out of the axle shafts than out of drive shafts. Those suckers are in there TIGHT! I've pounded the daylights out of some that just wouldn't budge. A bit of work with the hydraulic press finally persuaded them to get moving. [​IMG]
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    One of the main reason to touch up the yokes with some emery cloth and then never-seize before installing the new ones. Imaging what would happen if you were out on the trail without that hydraulic press when removing the old ones.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Harbor Freight u-joint press. About $30.
    Jim '80 GMC & '73 Blazer
    Body by Tellico
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
