best way to hook two yanks straps?
Discussion in 'The Garage' started by Jonny-K5, May 23, 2004.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    just came back from a day of mudding. wondering what the safest and most preferred method is of hooking two straps together.im getting tired of guys pinching my strap. i know you shouldnt use a clevis, i was thinking of maybe using a peice of wood, maybe 2x3x1.5ft interlocking both eyelets, instead of choking one eyelet into another. is this a good way to do it? is their another way?
  2. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    ??? /forums/images/graemlins/eek.gif
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    A clevis would be way better than friggin wood
  4. big jimmy 91
    Feb 21, 2004
    639
    I agree , don't fool around with with rigging that is put under alot of stress
    You could end up with lot's of damage or worse /forums/images/graemlins/yikes.gif
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    RJ, you crack me up /forums/images/graemlins/histerical.gif
    I don't get the idea of using wood though /forums/images/graemlins/confused.gif
  6. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I'd use the loop method or a 1" clevis and put blankets 4' either side of the clevis.
    I wouldn't use wood. Or else that piece of wood might be needed to build a pine box to plant you 6' under inside.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    how many disposable blankets do you carry in your truck?
  8. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Last time I didn't use a clevis to hook straps together I almost got me and the friend I was pulling out killed. /forums/images/graemlins/eek.gif
    DON'T DO IT WITHOUT THE PROPER EQUIPMENT AND/OR KNOWLEDGE
  9. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I have a cotton bale sized package of old wool army blankets, good for nto getting all muddy when lying on the ground under a truck and whatnot
  10. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I carry an actual "winch weight" which is a leather pouch filled with sand that uses snaps to hold it on the winch line. It looks kind of like a pair of saddle bags. Then I carry a thin chamois-like blanket that is heavy for working under the hood of my truck so I can lay it against the fender and not get all muddy. I use a 11mm thick piece of corrugated plastic used for screen printing when working under my truck.
  11. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    have you ever put a tire between two straps? /forums/images/graemlins/crazy.gif
    yeah yeah, it's honky, but when in rome....
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Let's see if I can explain this... Lay your straps out side by side, as shown below. (Ignore the long strings of periods. The forum software strips out "extra" spaces, so I had to put something in to keep the spacing correct).
    Slip loop "A" through loop "C" and slip loop "D" through loop "B". Now pull on loops "A" and "D". Loops "C" and "B" will slide along the adjacent strap until they meet in the center of the two joined straps. At this point they will interlock with each other. /forums/images/graemlins/cool.gif Now you have a longer strap, with no deadly projectile stuffed into the middle of it. It's also easier to get the two straps apart after the pull. Other methods will usually get you a knot that requires a lot of swearing and effort to get back apart after having been pulled tight by a couple of 6,000 lb trucks. /forums/images/graemlins/yikes.gif
    .. ____.......................................____
    . |____>--------------------------<____|
    ...A........................................B
    .. ____ ........................................____
    ...C........................................D
    /forums/images/graemlins/thumb.gif
    (Well, it seems that the "picture" will change, depending on the font used by your particular viewing scheme. Don't ya just love computers?) /forums/images/graemlins/wink.gif
  13. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i guess i wasnt very clear on how to use the wood,so ill use HarryH3's picture.
    1: hook loop A to the truck thats stuck, loop D to the pulling truck, then slip loop B thru loop C.
    2: slide wood thru loop B and pull tight.you need atleast a foot long piece so loop B cant pull back thru loop C. this way the straps wont pinch each other. the strap will take most of the stress, and the force needed to break a 2x4 like this is quite a bit.
    i've used this method when pulling loads out of trucks, but never when extracting a truck. the reason i think this is better than a clevis is because if something breaks i'd rather have a small piece of wood to worry about instead of a 10 pound chunk of steel.
    i like harry's idea better though, if it makes it possible to separate the two straps then it would be better than using wood or metal. i'll give it a try next time i go out. thanks /forums/images/graemlins/thumb.gif
  14. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    the wood sounds perfectly safe. it should just compress. not to be snotty, but the easiest way is to use a longer strap /forums/images/graemlins/thumb.gif
  15. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    When you mentioned wood I thought the way you ment was to tie a knot but w/ a piece of wood in the center of the knot. That is susposed to keep the knot from becoming too tight. Harry's way sounds the better,and its what I will try next time I need to join two straps and need the full legenth. If you can get away w/ loosing 1/2 the legenth on one, just slide strap #1 through one end of strap #2. Hook both ends of strap #1 to one truck and the free end of strap #2 to the other.
  16. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    haha, good idea. i never thought of that (not) /forums/images/graemlins/grin.gif just kidding.
    problem is sometimes you cant get within 60-80ft of the stuck rig if its deep in the mud, so unless you have a 100ft strap your gonna have to connect two.
    im gonna try harry's figure eight next time and see how easy it is to get apart.
    i like using that method if you can spare the length, but it seems like i always need every inch.
    does anyone know where is a good place to get a heavy strap? the one ive got is from 4wpw. its a 3"x30 that was around 60 out the door. i'd like to get another one, 4" wide and possibly longer, maybe 40ft. i'd also like to get a no name brand, the ones at 4wpw are pro comp and i think they tack on extra $ causs its got thier name stamped on it.
  17. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Hooking straps together with a clevis can be perfectly safe if done correctly. You want the clevis to be on the ground with no slack in the first strap. As long as you are using straps and a clevis that is rated properly there should be no chance of anything going wrong.
  18. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Check out these beastly straps! http://www.ultimate4wheeldriveperformance.com/recovery.htm I won one of their double 3-inch straps straps in a raffle. It is HEAVY DUTY!!! /forums/images/graemlins/waytogo.gif It's rated at58,800 lbs! If that isn't enough for ya, their double 4-inch strap is rated at 78,400 lbs. /forums/images/graemlins/yikes.gif
  19. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i dont understand what you mean, you mean have the clevis on the ground til you pull? even if you have properly rated equipment bad things can still happen. tow hooks for instance could rip off, especially if its a strangers truck. the bolts could be stressed and waiting to snap.
    and if it snaps off his truck, guess where that clevis is going?
    it might be alot safer to use a clevis correctly, but i wouldnt say its perfectly safe and no chance of anything going wrong
  20. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    whoa, i think i found my next strap, those are nice. and a good price too. what do you think about that magnum 9000 winch thats for sale below it? $549 is a great deal. that should be strong enough for a 1/2 ton blazer huh?
