Best way to lighten a K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigwishlist, Jan 16, 2003.
  1. bigwishlist
    bigwishlist Registered Member
    Apr 14, 2002
    47
    Sheboygan Falls
    What are some ways to lighten a K5? I want my K5 to be light. Light for a K5 atleast. Im gonna do rear discs to save weight. remove the top and doors for weight. Im thinking of doing a aluminum front fenders and hood. What else can I do to lighten the load? Thanks.
    Also how much does the top to a 74 K5 weigh? And a door to the same K5 weigh.
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I dont remember what company it was but someone makes a K5 body in fiberglass. The write up w/ the pics claims the weight difference in the glass shell equaled out to 2 inches in height. /forums/images/graemlins/thumb.gif
  3. 81sb
    81sb Registered Member
    Sep 26, 2002
    14
    Saskatchewan Canada
    I havent had mine off but I have read that going to a soft top will save about 300lbs, more if you take out the rear glass. That is likely the easiest way to lose a lot of weight.
    TB /forums/images/graemlins/k5.gif
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    If im correct the tops wiegh at the most 300lbs. If you want to lighten up the K5 go with all of the fiberglass body panels you can, take out all of the carpet and insulation, replace the seats with a set of light weight seats like beards or master crafts. You could also take the stereo out, remove the A/C and heater, go with aluminum wheels, run an aluminum transfer case such as a NP241, There are lots of possibilities for wieght removal, you just have to look in odd places.
  5. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I think the top is around 250#.Yes remove the top(250#),the tailgate(100#),the doors(80# each),strip the interior(50#?),no front wheelwells(20#),remove the heater/A/C unit(30-50#),alum intake and headers.You can get around 600# off with ease.I think that's why mine runs good with 39's and 4.10 gears,that and the SM465 tranny.The alum t case will get rid of some weight too.Just start pitching everything you don't need!My latest project is cutting 12" out off the width and 8" off the bed.Fiberglass panels will save some weight,but will sacrifice strength.You would be amazed how much you can take off.The '81 and up front clips are a little lighter.Have fun with a sawzall!!
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Dana 30 axles, drop a 4 banger in there and less gas in the tank
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    If you want to really lighten up your K5 go to ORD and see what steve did to his. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rolleyes.gif
  8. muddysub
    Jun 23, 2001
    10,454
    493
    my garage, Henderson, NV
    has anyone seen the article in the new petersons, a pro-rock 60 with 100# shaved off. check it out. it's amazing. dynatrac has gone insane with this one. fluted heat treated chromoly axletubes, aluminum cover, rifle drilled and lightened 35 spline shafts, wilwood discs (rear axle) and a strange heat treated chromoly spool. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif makes it 33% lighter!! /forums/images/graemlins/thumb.gif and it looks frickin awesome!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/pimp1.gif
  9. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I dont think anyone else said it, but the back seat is about 50#'s. /forums/images/graemlins/thumb.gif
  10. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    Fiberglass panels would be an easy way to fit some bigger tires also. Fiberglass is actually quite strong and i have heard a few stories about it cababilities. Thats in the summer though. In the winter is where strength becomes an issue, thats why u dont drive a vette in the winter.
  11. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Lots Of great ideas here now lets move this to the next leval so to start aluminum intake and heads and what to hell if ya got the $$ go to a titanium or alum block with steel sleeves carbon fiber hood and panels alum roll bar and run a alum radiater and a carbon fiber core suppoert now for the fun stuff have a 205 t case built for you out of titanium and while your at it do the axles also ar at least air craft alum with steele sleeves for all bearings parts
    and cut your side panels off from behind the doors down to the floor board then get your F*%&^# fram made out of that new fiber composite that Nascar is using well i am sure you get the idea by now and finnally fill your tires with helium and your k5 will float :-) hehehehe lol /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Remove what you don't need...
  13. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I personally dont think there is any way to lighten a K5 if you plan on doing major modifications. I cut off my doors, took off the hard top, gutted the interior, then installed lighter seats. Cool, it should be close to or slightly under 4000 pounds right? Now add a D60. That fat pig weighs as much as both of the 1/2 ton axles. Its like 650 pounds!!!! Then add the 14FF even with disc brakes its still a huge hunk of steel add 400 pounds for that. Then a stout roll cage 60-70 pounts. A winch is 80 pounds or so.
    I just give up....
  14. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    the top is right around 200. if it were not so bulky i could easily pick it up myself. and im a skinny lanky SOB.(6'3'' at 170lbs, yeah, im a stick)
    BUT, inner fenders, glass hood, or remove the inner support on the hood, the hinges and pin it down front and rear.
    doors, and tail gate.
    skinny tires.
    and all the AC stuff.
    grant
  15. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    Very wise 90K5, but you forgot about Helium in the tires.
  16. rogerwilco71
    Sep 22, 2002
    179
    Central-Cal
    NOW WAIT A COTTON PICKEN MINUTE! That's what bucket seats look like, that guy at Jeg's lied to me. I also like the custom lamps attached to the bed for a natural ambient light source for mood-lighting. [darth vadar voice]impressive[/darth vadar voice]
  17. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    LOL! Those are the "budget" bucket seats from Home Depot... /forums/images/graemlins/wink.gif
    BTW, the rear is not setting that high after adding the rear fuel tank and the cage...
  18. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    BRAVO !!!! there Baddog now that is what ia m talking about !!!!!!
    hey get the plastic cup off the back bumper its messing up your spring rate ratio /forums/images/graemlins/rotfl.gif
  19. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    My Blazer used to be over 6100 pounds. I dumped the back seat, Put disks on the rear, went to headers, Put on a soft top and removed all of the guts from the tailgate. That put me down to about 5400 pounds. That was with the doors and the tailgate on. I plan on seeing how heavy it is with those things off next. I've been thinking about fiberglass body panels next. Like the hood and then maybe an aluminum radiator.
  20. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    An aluminum engine block out of a new vette would help a lot too! /forums/images/graemlins/thumb.gif (in more ways than one)
