Best way to "Mark" Hand tools?
Discussion in 'The Tool Shed' started by dbreid, Feb 18, 2007.
  1. dbreid
    dbreid 1/2 ton status
    Dec 26, 2005
    379
    San Mateo CA
    I am sure many other people have the problem I am facing, but I figured I'd post here to see what you all use as a solution....
    I have TONS of hand tools. I work on vehicles of all sorts (Metric, Standard, etc), and as a result have wound up with many sets of tools, mostly overlapping. For example, I work on VW's a lot, and I would guess I probably have 20 13mm sockets.
    I have attempted several times to make tool "kits" for each of my vehicles. You know, just put in all the tools that are actually used for the vehicle... etc.
    However, every time I do this, I eventually wind up "mixing" the tools, and then I forget where they all go, and I have to re-sort everything.
    I'd like to "paint" or "mark" each tool set so that I can easily sort them out. Is there some sort of paint that will adhere to Chrome tools? Should I use electrical tape in different colors? What do others do in this situation?
    Thanks, Dan
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Use an engraver.
    I guess I don't follow too well. I have two sets of tools.... my main set in my shop box that stays in my shop, and my tools that are in my K30 service truck. Both sets have everything I basically could need to work on anything I have. When I need to work on something, either set does everything.
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    The road crews with the detail company used to have differnet colors for van setups.. red, blue, etc... standard krylon will hold up for quite some time.. for cheaper stuff, why not... we used to just paint 1/2 the tool...
  4. dbreid
    Dec 26, 2005
    379
    San Mateo CA
    Yeah, I was planning on painting stripes on the "Suburban" set, and then Stripes on the "Jetta" set, etc. I'll try the Krylon. :)
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    yeah, we would just make a pass with krylon...
    another thing that would probably work good would be a couple different color paint pens.. nice mark on a non wear area...
  6. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    paint pens work well... so does an engraver...
  7. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    Lift your leg... :haha::haha:
    seriously, x2 on the krylon if you're like me and have no patience to engrave everything. Obviously engraving is the best solution but krylon is convienent and easy. Especially if you decide to change things up down the road.
  8. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    I painted my stuff with the safety orange spray paint to keep them from getting lost on the trail/dirtbike track. Looking back though I wish I would have painted my standard and metric stuff different colors.
  9. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Yep, paint. Cheap, easy, fast.
  10. Craig Artzner
    Craig Artzner 3/4 ton status GMOTM Winner
    Dec 16, 2006
    6,843
    Northeast Ohio
    I engrave my initials in all of my tools. It's the best (and most permanent) way to mark your tools in my opinion.
  11. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    all my tools have some sort of neon green paint on them somewhere, that way i know my tools from all my friends tools. Plus, who has neon green paint that they regularly use. This works for extention cords as well, being in a rental business, customers always try to say hey, thats my cord, i usually show them the neon green cord caps that way there is no arguement.
