Best way to move frame?
Discussion in 'The Garage' started by 84gmcjimmy, Dec 27, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I originally planned to lift it with the engine hoist and have a friend and I balance each end, then have someone push it to the shop. But now we have 5" of snow, so it's not possible to use the engine hoist.
    How can I move the frame into the shop? I think someone mentioned it weighed around 300 poounds. I want to move it soon so I can gett hat out of my hair, and spend some moola on POR-15.
    Any ideas?
  2. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    2 guys and some muscle... i dragged mine around the yard by myself quite a bit...
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    do you have a come-a-long yet?
    stick that on the frame with or without wheels and crank away.
    or if you dont. tie chain or good size rope to the fron of the frame and put it through a loop in side your shop appasit to the door, run it back out side and tie the rope to your other truck car or your lawn tractor and pull backwards it will pull in.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i moved my longbed frame around by my self. it was heavy and hard work, but i did it. a come-a-long is probably your best bet.
  5. dyeager535
    26,979
    Bare K5 frame?
    My dad and I carried mine around the yard when I was assembling mine. Actually had a steering box and tank on it, but that doesn't add too much.
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Alright thanks, I will see if I can get a friend over and move it into the shop. It's the bare frame, except for motor mounts, brake/fuel lines, and crossmembers!
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My wife and I managed to get a K5 frame off of the garage floor and onto a trailer. :laugh: The total trailer load was 380 lbs.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    it is not that heavy
    push it, it will move, unless theres really that much snow,
    i weighed a bare longbed frame once and it came up to hair over 200lbs with crossmembers too
    good luck
  9. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    well u sed there was 5 inches of snow right? lift it up and put some sleds under it and just pull it :D
  10. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    we ued a winch/boom set up to put a truck together from the frame up,breaks, steering, suspesion, axels, cab, motor, tranny, t-case ect in about a week with just a few hours a day. And this truck was a rust bucket, no easy bolts here :(
    works great for installing axels too....hehe
  11. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    you got a hi-lift jack? if so you can get under one end (side furthest from where u wanna go towards) and jack it up a little at an angle (towards where u wanna go) it works great.
  12. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I'd go buy a bunch of those plastic tobogans. The long narrow types and put them underneath it. Then you just slide it over that snow. If its only 300-400 lbs. couple sleds out to do nicely.
    Edie: if you do it this way I want to see pics!
  13. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    wheel it!
    I've moved bare frames by bolting some wheels onto the frame using the stock holes in it--or a hand truck laid under a crossmember,and pick it up like a wheelbarrow.. If its snowy and small tires sink in,you can drag it with a riding mower and a peice of plywood for a "toboggan"--I use my yard-man rider for a lot more than mowing!--its a wrecker,dragger,pusher,and step saver when your working 300 ft from the garage..you'd be suprised how much weight you can pull with a riding mower--mine is a 20 hp hydrostatic,and will tow my truck on bare asphalt!--even some of the wimpy 10hp ones I've had will skid a 40ft 6-8 inch tree out of the woods!!...I try not to lift or drag or push anything by hand anymore--too much risk of back injury....:crazy:
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I have 2 plastic snow sleds I've had since I was 10 I could use, If it doesn't work its just a pile of plastic I have to clean up. My ride on lawnmower isn't working, so I will probably pull the Jimmy out and try to pull that with the frame on the sleighs. Then question is, how do I get it out of the carport. I have a hand truck I could use, like someone suggested.
    We'll see...
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I have a high-lift jack.... but it's quite a few years old. I don't know if it's broken, or if it's just wearing out. But it doesn't work very well. I almost tipped the frame over using it a week ago because I couldn't get it to go down again.
    That will be my last resort.
  16. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    That would be a nice way to do it. Is that a rental, or does your family own it? LOL I don't have one, so it's a no go:grin:
  17. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Well I never got a chance to tackle it today, but maybe tomorrow I will do it.
