Best way to relocate rear axle??
Discussion in 'The Garage' started by Masher, Feb 11, 2003.
  1. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    I will soon be swapping in a 14FF with new 6" springs and an Echobit shackle flip with 6" shackles. I know I will probably need to move the axle back a little after all this. Can I just redrill the perches to move it back a little or should I order some zero-rates to move it back?? I really don't need the extra inch the zero-rate would give but what is the best way to do this??
    Thanks.
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Your probably gonna need some shims anyways, and I think Atron can get you shims w/ an offset.
  3. Masher
    Mar 7, 2002
    123
    SW Michigan
    I was planning on cutting and rotating the perches to get the pinion angle set.
  4. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I personally drilled out the perches and top plates to move my axle back 1 1/2'', no problems yet /forums/images/graemlins/thumb.gif. I actually ran the center pin all the way through the perch so that the spring pack/top plate/and perch are all bolted together as 1 unit ; but this was on a 12 bolt and would not work on a 14 bolt (I don't think /forums/images/graemlins/confused.gif) because of the solid perches but you can still just drill so that the pin sets into the perch. Just my $.02
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Yeah, the atrons shims are available with an offset.
    With the echobit shackle flip and stock shackle, the 1.5" offset atrong shim centered my wheel in the wheelwell nicely.
    Couldn't be happier with the A-trons.
    -- Mike
