best way to remove bushing from shackle?
Discussion in 'The Garage' started by stoney126, Jul 7, 2006.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    Hey all, I need to replace the bushings in my rear shackles. I dont have a torch so what would be the best way to remove them? Thanks for any info
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Clamp them down to a table. Use a small drill bit and make as many holes as possiblearound the sleeve. Pound the sleeve out as much as you can then grab it with vise grips and twist. You should be able to work it out. I just did mine the other night PITA, but the shackles are easier than gettin the ****in sleeves out of the spring eyes:mad:
  3. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    Lubing them up with PB blaster or WD40 also helps. I used a big socket and hammer to pound mine out.
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    A search helps alot!:D
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Start the rubber on fire with a Torch. A small propane works well too. Burn it out and it will all fall out on its own. Very smokey and stinks.
