Best way to spend 5K on motor?
Discussion in 'The Garage' started by BranndonC, Oct 23, 2003.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    so i figure that by new years I'll have at least $5000 saved up. So my delma..... I'm looking for around 400 HP and 450 TQ
    Also i need it to be TBI or TBI. I have to pass the California emmitions /forums/images/graemlins/frown.gif
    Small Block GM good wrench replacment stock motor and whipple
    Small block hopped up to put out the power i want
    Big block hopped up
    I realize i will need a new tranny, that will come in about 2 months after the motor. so for what its worth i'd like all options. I know small block = lighter and cheaper parts and big block = heavier, better low end TQ and more expensive.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just throw out the idea of supercharging a stock Goodwrench motor. IMO, a motor should be built specifically for supercharging if that is the goal. That means low compression forged pistons to go with the rest of the forged bottom end, a good balance job, and the biggest set of heads that the budget will tolerate.
    What is the goal for use of this truck? Why do you want all that power?
    In your case a big block would probably be your best bet...but I don't know if that'd pass emissions or not.
    I know that a hot small block would be a blast, but if low speed off roading is in your future, that'd be a definite no go.
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    my uses for the next 2 1/2 years will be for DD about 85% but after that switched and 85% offroad. So i just have the $ and need a new motor anyway (mines becoming such a dog) so i figured why not get the power i'm lacking
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why not get the power you're lacking?
    Simple, it's hard to do with EFI. Low end torque is easy to make with EFI because that's what it's great for. To get it to breathe over 5,000 RPM to make that kind of peak HP might be a little harder.
  5. VisionxOrb
    VisionxOrb 1/2 ton status
    Oct 10, 2001
    251
    Newbury Park, Ca
    383 internal balanced nice heads like afr 195s, good broad cam like compcam xe268, headers good exhaust, perferibly tpi ( runs out of steam at 5000rpm but youll allready be at over 400hp and around 450 tq)
  6. jekbrown
    May 19, 2001
    45,029
    361
    Vancouver, WA, USA
    yeah, Im thinkin 383. /forums/images/graemlins/thumb.gif
    j
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
  8. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    straight up...FO' 'FITY FO'
    Since I put my 454 TBI in my truck I could never put a 350 back in there...
    Chris
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    compcam xe268
    A Comp XE 268 is not emissions legal. I doubt it'd pass in CA even if it didn't lope.
  10. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Best way to spend 5K on a mill? John Lingenfelter.
  11. VisionxOrb
    Oct 10, 2001
    251
    Newbury Park, Ca
    ive passed with a crane 276/284 cam which I believe is bigger than the xe 268, as long as everything else is working good should have no problem
  12. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    Just my 2 cents
    Chevy crate HT (High Torque) 383. That might not quite get you there in HP but you will pass your torque expectations. www.sdpc2000.com You can check there to see it and other options plus if you want more info on it pm me and I will try to find the Hot Rod article on it with the dino charts and scan it off for you.
  13. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    find a nice 4bolt main block,forged 4340 crankshaft,good set of rods,blower pistons,weiand 6-71 blower kit, carbs. usally you can find nice used blowers for a lot less than new...check out racingjunk.com. you can find all the parts you need there......
  14. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    SAVE ANOTHER $5K AND GET THE RAMJET 502 F/ GM PERFORMANCE. Or, check out the 383 from GM as well. If I had 5 grand for a motor, 454 or 400 would be good for me. There's a lot out htere for 5k.
  15. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    no one will be able to tell what you got on the insides. most places around me, for smog, are worried about the visual, since you can tune a decent vehicle to pass. I'm mission the "stove pipe" and that's it. so i failed. it sniffed clean (leaned it out) and so a motor with decent specs and the factory emissions will work great.
    Why the HP number so high? more power = more busted parts. a nice little 300HP motor would be reliable, streetable and alot easier on the rig as a whole.
  16. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    I've got a great idea:
    GET THIS!!
    Then all you need is some minor stuff like:
    Crank
    Rods
    Pistons
    Rings
    Bearings
    Heads
    Intake
    Exhaust
    Fuel Delivery
    Cam
    Valvetrain
    Balancer
    Oilpan
    Plugs
    Wires
    Should allow you to hit your power target too.
    /forums/images/graemlins/grin.gif
  17. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok well i just called a somewhat local shop and they said it was impossible to get 400 HP and 450 TQ and be smog legal /forums/images/graemlins/confused.gif the only reason i want that kinda power is because i dont know what it feels like and my motor kinda feels like its a dog, so i just thought why not get the power. it looks more and more like i might just get this one that i've had bookmarked for like 6 months 383 HT
    can someone tell me weather or not this engine would bolt in easly and be compatible with TBI ?
  18. Emmettology 101
    May 9, 2000
    8,126
    FL
    Well they're smokin crack! Lingenfelter re-did an LT-1 vette a while back with 660hp and smog legal. Also, I saw a thing where he did a 770hp Twin Turbo Escalade EXT in CA.... Have you tried calling them?
    My opinion would be to keep it somewhat simple and get a Ram Jet 350..... Much as much HP but a nice engine.
  19. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    also, Car Craft did a report a few years back and had sniffer tests done on some strip cars. One was a 69 Camaro Pro Street. 8sec ET's, 632 Cube engine, dual BG dominators on it, no cats, etc. etc.
    It passed. Granted, it only had to pass Gross Polluter regs, but it passed.
  20. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    383 with a TPI kit!
