Best way to support an engine while replacing rear main seal...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Mar 25, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I am going to pulling my tranny this weekend and begine swapping in the stuff for my manual conversion...while I am in there, I plan on replacing th erear main seal on my engine...what do you all feel is the best way to support the engine when I drop the oil pan? to do the seal...I have actually thought about renting a engine hoist for the purpose...any ideas?
    Chris
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    I let my exhaust system and motor mounts support the motor...
    Rene
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    The motor mounts will hold the motor in place, you don't need any additional support.
  4. TULSAK5
    TULSAK5 Registered Member
    Feb 20, 2002
    93
    Broken Arrow, Oklahoma
    Jack stand under the oil pan. Don't let it rest on the motor mount. The rubber will separate from the steel. Another thing, watch to make sure the distributer doesn't hit the firewall. This can bend the shaft or crack the cap.
    Chris
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You do want to support it with more than the motor mounts. It weakens them putting that force on them ( the motor rocks back). A strap from the motor to the radiator support, frame, where ever is enough. You just need to take the tension off.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Won't the jack stand under the oil pan make it pretty tough for him to remove the oil pan? /forums/images/icons/wink.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Welcome to the world of 1 piece rear main seals, my friend. /forums/images/icons/smile.gif You've got a '75, I've got an '84, and both of us were thinking the same thing for a minute there.
    I have an '87 1 ton 2wd with a 1 piece rear main seal though, and, looking at it, it can probably be changed with the oil pan on.....but I'm not for sure, it doesn't leak so I'm not messing with it.
  8. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    The best way is to suspend the rear of the engine from a hoist. Do not ever support an engine by the oil pan because it compresses the gasket and will cause leaks.
    John
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd just let it fall back in the mounts. Both of my trucks are in my garage right now with the transmissions out of them, and that's exactly how the motors are sitting....in the mounts, rocked back.
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Ahh, since in the main post he stated that he needed to drop the pan, I just figured that he was changing out an old rope seal. /forums/images/icons/cool.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Rope? What's the point in changing one of those anyway? Won't it leak no matter what you do?
  12. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    That what I thought:) (rope seals)
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yeah, but new ones leak slower than old ones. /forums/images/icons/wink.gif
  14. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    What kind of seal do you have? What year is your engine?
    I must have missed that part....
  15. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    1987 K5, 350 FI, so a 1-piece rear main....
    Chris
  16. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    a 4x4 with chains drooped over on each side bolted to the heads.
    grant
  17. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I would use a jackstand with a block of wood.
