best way to tint windows?
Discussion in 'The Garage' started by bigbadchev84, Jun 30, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    well without a/c in my truck i am finding that it REALLY sucks. i was wanting to tint the windows in my truck with the stuff you buy at walmart, i have installed it in my other truck with fair-poor results, mostly because around the edges there always seem to be grits of dirt and whatnot, prior to installing i wash as god as i can with windex then wipe with rubbing alcohol. does anyone have any tips on how to get a moderate to professional look out of it?
  2. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    If you don't have a/c you should be rolling the windows down anyway, so what good would tint do?
  3. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    just wanting to lower temps while it sits locked up in the parking lot at work all day in the 100+ temps
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Park so that you'll be facing the afternoon sun, but stick one of those cheap, folding cardboard sunshield things behind the windshield.
  5. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    use a dab of dishsoap in a spray bottle. soak the clean window with solution, place tint on it, soak top of tint, squigee the water out, leave alone for 24 hrs.
  6. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    What kind of tint is best to resist UV/heat? The kinda that's reflective, but not dark? :confused:
  7. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
  8. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    also i cut the tint a little bigger, put it on window(squigee it) after it has taken a bit then use sharp razor to cut it on the glass. also get a good squigee(am i spelling that right?)
    takes a bit o practice but by the 3-4 one ull have figured it out
    oh yeah slight reflective is way better btw. (check local laws on how dark or refective u can get away with if u go to much)
