Best way to tow my Blazer
Discussion in 'The Garage' started by Luehrs1, Mar 5, 2005.
  1. Luehrs1
    Luehrs1 Registered Member
    Feb 5, 2005
    48
    Jacksonville
    I live in Texas and am moving to Florida. I don't want to drive my Blazer all the way there. It has a 4" lift and 33" tires. Would a tow bar work or is a trailer needed? Thanx.
    Patrick
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Tow bar would work, but unless your tow rig is substantially bigger, its not recommended.
    You could make the tow bar work just fine, you just have to install a brake buddy, which will activate the brakes on your k5.
    You may acutally net better fuel economy using a trailer however. The skinny narroow high pressure tires wont scrub nearly as much.
  3. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    KennyW just towed my k5 to 4wheelerJeff in Colo....
    4 inch lift and 33...
    other than the fact I didnt tighten some body bolts and we lost some pucks I think it towed ok,,,,
    kennys rig is pretty stock...k20
    cam
  4. Luehrs1
    Feb 5, 2005
    48
    Jacksonville
    Did you use a tow bar? I found a 6'x12' trailer would that work?
