Best wheel width for 12.5 tire?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigk, Sep 23, 2001.
  1. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    I'd like some opinions on the best wheel width for a 37x12.5 tire. 8 or 10? Thanks in advance.
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I've been running 12.5" tires on 10" wheels for a few years and I like it. I've seen some others run them on 8" wheels but if the pressure is not correct they'll wear in the center more than on 10" wheels
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    10 would be prime, but they can be hard to seat, and starting fluid isn't as cheap as it used to be. 8" w/ 37's should be ok because the big amount of sidewall, it makes a less dramatic taper, on 15" rims i'm assuming.
    Tork DSR
    I just got a winch, it takes the fun out of things.
    http://www.torkpig.homestead.com
  4. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    The rule is, keep the rim width within 1 inch of the tread width. Since most 12.50 tires have about 9" tread width, you guessed it, 8 or 10 are both acceptable.
    Best bet is to measure the tread width of the tire you want to run before you buy rims. Keep in mind, that's TREAD width, not section (sidewall to sidewall).
    Poundin' the ol "pavment"!
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have had both, I like 10" better.
    Tim
