Best year(s) for a D60 front-end
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fad2blk99, Feb 18, 2004.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I'm ready to get serious about hunting down a D60. Diff and gear ratio doesn't matter cuz I'll be going w/ 5.13s and a locker (unless of course I'm lucky enough to score one w/ this setup). What are the best years to get and which ones should I steer clear of? What are the year/make/models for the 16, 30, & 35 spline inner/outer setups. Any info would be greatly appreciated...
  2. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    85' and later had 35 spline outers.
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I dont think any Dana 60s came stock with 35 spline outers.
    My 60 is out of an 88 military K30.I dont realy know the best years but as long as it is an open knuckle,GM model its gonna have 35 spline inners.
  4. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Here is a link to the Dana 60 bible.Just about everything you could ever want to know about a 60 is in there.
    The Bible
    /forums/images/graemlins/waytogo.gif
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    85 and up. the reason is because the shafts that SHOULD be in the axle are the NON neck down inner shafts, 35 spline. and the 30 spline outters.
    Grant
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    is that the same for dodge D60 (please please please be so) /forums/images/graemlins/grin.gif
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Should be.
  8. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
  9. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    my 60" is a 87 and it came with 35 spline inner axels,30 outers which were replaced with 35 spline Stubs
  10. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    The bible says Dodge and chevy are almost the same. I got a 90 D60 and it says I got the beef for inners /forums/images/graemlins/woot.gif
  11. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    The non-neck down, fat inner axles started around '79/'80.
    I personally think vehicle mileage and intended use play a much bigger factor in which axle to get (assuming you have a choice of more than one). All Chevy D60's from around 80 thru 91 will be basically the same so you really need to concentrate on what kind of shape it's in (ie; rotors, bearings, etc).
  12. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    /forums/images/graemlins/thumb.gif Thanks guys! this was just the info I was lookiing for....
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    9) Chevy/Dodge uses six 1/2" spindle studs, Ford uses five 7/16" spindle studs
    10) Ford knuckles seem to have more issues with the upper kingpin area strength than others. Chevy/Dodge knuckle has thicker ribbing around the upper kingpin area.
    hummmmmmmm
  14. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    and that's why we don't buy fords /forums/images/graemlins/doah.gif
  15. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    No. The 35-spline stubs were exclusive to the Dana 70 front axles. AFAIK, ALL GM Dana 60's have 35-spline innnser shaft and 30-spline outer shaft. The biggest differnece in the GM D60's is in the inner axle design. the Early ones had neck-down shaft and the later ones has non-neckdown shafts for the inner axles...
    Chris
  16. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Yeah and Ford outter (outer knuckles, spindles, hubs and caliper and brackets) are very screwy...different altogether.
    Chris
