Better choice 502 or 350?
Discussion in 'The Garage' started by shockline, May 23, 2006.
  1. shockline
    shockline Registered Member
    May 10, 2006
    51
    Powhatan Virginia
    I have a delema, I have a 502 just sitting in my shed, and I got a 305 in my blazer that is a dissapointment to say the least.
    If I put the 502 in will i start breaking parts and have to replace my drive train?
    I got a "friend" that wants to trade me a 350 with aluminum heads and approximately 400 hp, install and give me 1500 in cash.
    What should I do? I am leaning toward the 502 but I dont have lots of part money. The 502 is rated at 450 HP and 550 torque. It is a marine engine and has not been used before.
    :confused:
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    What do you want to use this truck for?
    MUD=502
    Rocks=350
    Sand=502
    That's not for sure, but just the more practical appications. Personally, I would be all about the 502. What drive train do you currently have? It may be kinda parts hungry.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    no replacement for displacement...
    id say 502......
    :bow:
  5. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    do you even have to ask? You wont break parts if your easy on it! Plus its 50hp difference, not much.
    edit
    the logical side of me is thinking
    the 350 is lighter, 50hp less, and probably better gas mileage. plus you'd get some cash in your pocket.... I'd use the 502, but I just like big engines
  6. shockline
    May 10, 2006
    51
    Powhatan Virginia
    Thanks for the quick reply, my 84 k5 has a stock drivetrain with a 350 turbotrans. I am not so much worried about the HP as I am the torque. As far as going easy on it I am not good at that. In real life I need it to pull my boat and the 305 does not pull up a mountain very well. In my dreams I want to get crazy with it.
    I live just down the road from Bodacious and I went to the meet last weekend and now I have the fever for 4X4. If you want a good competition ralley on private property where ANYTHING goes, you should check it out.
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Put in the 502 and put a lag bolt under the skinny pedal to limit its travel like U-Haul.....
  8. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    If you wanna tow with your truck run the 502. It won't care what you put behind it
  9. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I woulda said go with the 502 until gas hit $3.50 a gallon!
    Eric M.
  10. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    If torque is what you want then the answer is obvious.502
  11. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I say go with the 350 and I'll "dispose of" the 502 for you. :haha:
  12. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    another vote for the 502, lots of torque and plus you will have the bragging factor
  13. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    502 the 350 will never make the tourque this thing will. It will sure make it fun to drive
  14. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    If you can afford to put the BBC in - and do it right - then do it.
    However, if you can just barely afford to do the BBC, then stay with the SBC, and do that right instead.
  15. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    x2.
    if they are both FI'd... and you can afford to upgrade the parts behind it... 502 all the way.
    j
  16. shockline
    May 10, 2006
    51
    Powhatan Virginia
    The people have spoken; its going to be the 502. I have the complete marine engine and all the parts except exhaust. Do you know of anyone that makes a set of headers for the 502 and 84 blazer?
    How do you think the turbo 350 will hold up against 550 ft lbs of torque? or the rest of the drive train for that matter?
  17. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    :bow:
    If you enjoy the skinny pedal, go ahead and start looking for a tougher drivetrain. I would get a very heavy duty tranny cooler at the very least.
  18. resurrected_jimmy
    May 23, 2005
    2,241
    The TH-350 will live. Its a pretty tough transmission. Your 10bolt axles will be the first thing to let go. If your going to tow with it regularly you might as well start looking for a 6 lug 14SF.
  19. shockline
    May 10, 2006
    51
    Powhatan Virginia
    I live close to Norfolk Virginia and they have a military surplus yard for truck parts. Cost not being a factor, what rear and front should I look for. I am pretty knew to the chevy family, all my other projects had been ford cars.
  20. resurrected_jimmy
    May 23, 2005
    2,241
    Oh man you shouldn't have said that.... :rolleyes:
    Go pull the axles out from under one of the 1 ton ex-mil chevy pickup's. Its a Dana 60 front and a 14bolt full-floating rear with 4.56 gears. (edit) The military designation is M-1008, utility truck.
