Better front shocks
Discussion in 'The Garage' started by SubYuman, Dec 5, 2005.
  1. SubYuman
    SubYuman 1/2 ton status
    Oct 13, 2001
    246
    Edwards AFB, Ca
    EXTENSION 16.21 Collapsed 10.68
    Lower end is an EYE mount, upper is a stud. If I could make a remote shock work, I would. But since the shock goes into the coil spring, there's no way to run the line since the spring goes into the frame, the upper spring cup is inside the frame rail.
    Fabtech built the shock pass thru much larger than stock, so a better, wider shock will work. I had to clearance the hole on the stock lower arm.
    Any help?!?
