BFH Time!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89OKIE, Nov 27, 2001.
  1. 89OKIE
    89OKIE Registered Member
    Aug 16, 2001
    11
    I HAVE DONE EVERYTHING I CAN THINK OF TO FIX MY BRAKE PROBLEMS.NEW- PADS, ROTORS, CALIPERS, AND RUBBER BRAKE LINES. HAD THE BACK ADJUSTED AND ALL THE LINES BLED. THE THING STILL PULLS TO THE RIGHT AND EVEN WORSE AS THE ROTORS HEAT UP. IS THERE A VALVE OR AN ADJUSTMENT SOMEWHERE? GOT NEW WHEEL BEARINGS ALSO. ANY IDEAS? IT'S GETTING DANGEROUS!!!!!!!!!!!!
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    There is a proportioning valve up on the front crossmember, worth a look.
    <a target="_blank" href=http://new.wavlist.com/movies/031/ag-blow.wav>"I ain't nobody, dork."</a>
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I thought that was front to back proportioning. Has your blazer ever been wrecked? Mine used to pull a little bit to the right too. I removed the sway bar for fun one weekend and it quit pulling. Turns out the front end had been hit and the sway bar was tweaked. Anyway it quit pulling when I braked. Not sure of the corallation, but I left it off! Maybe a bad tierod end?
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Maybe you could take it out on a loose gravel road and try a moderate stop. It will be more apparent if only one front is braking. if you have even braking up front you'll know to look elsewhere.
    I'm assuming you checked the air pressure in both fronts? How are the wheel bearings?
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    I would definately check for worn suspension parts. Sounds to me like it's more than a brake problem.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  6. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    And check the balljoints, steering linkage, too.
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    Welcome to America.
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    check the rear wheel cylinders...sometimes one gets messed up and doesn't work
    90K5
  8. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    caliper guide pins? where those replaced with the calipers
  9. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i had the same problem on mine. i changed the calipers two times, bleed the brakes 100 times, changed pads, even replaced the porpr. valve(didn't know at the time it controled front and back). well i solved the problem by replacing the pads again, i was using sh$ty autozone pads so i switched to pep girls (raybestose) pads. and the result, problem fixed. i also had the rotors turned and that helped even more.
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    A bad shock can also cause it to pull to the side when braking. Even a bad one on the rear can cause problems.
    I had a bad rear shock. My K5 quit pulling to the right when braking, when I put new shocks all the way around.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
  11. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,088
    488
    Grand Rapids area
    Both rear brakes are fed from a single line. If one wheel cylinder is messed up, the rear brakes can pull to the side, but it won't make the front brakes uneven. Bad pulling from the brakes is almost always a problem up front.
    Something else to look at is to make sure that there is no rust or dirt behind any of the brake pads. Some of this stuff is compressible and takes up some of the slack in that side, putting less actual pressure on the pad-rotor interface. "Anti-squeal" shims that are old or bent or even "disc brake quiet" adhesive can sometimes have this same effect.
    It is critical for the guide pins, little sleeves and caliper sliding points be clean and greased.
    <font color=green>Oh man, 4:10's are sure better than 3.08's!</font color=green>
