BFH to remove D60 steering arm?
Discussion in 'The Garage' started by stoney126, Aug 27, 2006.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    hey all, I need to remove the steering arm to place a block underneath. In order to get it off do I just smack it ?
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    if it doesnt pop off when you remove the 4 bolts, you should probably look into replacing your kingpin springs while its apart. every one i've ever removed has just popped up when you loosened the bolts.
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Mine came right off from the springs tension when I removed the bolts.
  4. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    dang something else that needs fixing :o
  5. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I must say look into crossover...Its not that expensive and can save lots of trouble, possibly lives! I busted this 1 after 1 year and luckily it was in a driveway backing a trailer 40 miles from home..That sucked!:mad: No steering. But if you do use the block the arm should pop right off with a hammer.
