Bi-curious
Discussion in 'The Garage' started by Craig Artzner, Apr 21, 2007.
  1. Craig Artzner
    Craig Artzner 3/4 ton status GMOTM Winner
    Dec 16, 2006
    6,843
    Northeast Ohio
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Never seen that combo before, just one or the other. Don't the propane burners use a different fuel mixer, in place of a carb ?
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I was doing some research about a while ago and this is what I came up with (on our older trucks, I have no idea how well they work on new FI'd ones)
    You can run a truck three ways
    Dedicated Gasoline--i think we all know how this works.
    Dedicated propane--you can run a previously gassed motor with no ill effects although propane has a higher octane rating, therefore you must retard or advance (I forgot which) the timing to deter pinging. You replace the complete carb with basically an injector plate and the other typical propane setup. Now if you build a motor specifically for propane you can get more everything out of it as per the higher octane.
    Gas/propane setup--you basically put an injector plate above the carb(with the typical propane stuff) and you run a switch to either run propane or gas. Now with the propane being a higher octane you basically set the timing to run decent with both, and that is typically why people say you loose power with a bi setup. now theoryetically (sp?) you can get out and change the timing everytime you change but who is really going to do that?
    If I do it im going to run a dedicated propane
  4. Big Blzn
    Big Blzn 1/2 ton status GMOTM Winner
    Jan 30, 2006
    3,587
    Orange County, CA.
    A lot of construction equipment such as boom lifts, scissor lifts, fork lifts etc run gas and propane options. I'm in this business and they seem to be very reliable.
  5. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    Alot of the stuff at work is also a gas/propane. I never really looked at it though since we only run propane indoors.
  6. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    i have been doing alot of calling around and reading on this subject for my 07 chevy
    cost 2000 to 2500 for the set up plus a tank 400-1000 for my 6.0 motor
    i am on the fence but my mind is really on this. i use 2 or sometimes almost 3 tanks a week. 1 tanks is 34 gallons, call it 70 gallons a week, thats 280 gallons a month on a very conservative guess. so more kike 300 gallons.
    3000 cost to convert
    propane is on avaerage 1.99 or less here, gas is right at or under 3.00
    in 10 months I brake even. I suspect the price of fuel to lower and climb and continue to level off higher and higher.
    some benifits,
    propane less depended on issues oversea's?
    I can store propane on my own property with little paper work
    tax write off
    drawbacks.. fill ups are not as easy to find, upfront cost, and mounting the tank.
