Bias Tires On A Dd?
Discussion in 'The Garage' started by stockk5, Jan 23, 2006.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    im looking for some new tires and cash is a problem, and ive noticed the radials are $$$...especially for a teenager, does anyone know how bias tires around 38x15x16 or so would be for a DD, i dont do highway much at all, i go about 45 or under for usual driving.:confused: should i pinch my pennies for a long while and get radials?
  2. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    they only suck the first 20 min in the morning, then they round out.
  3. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    Get radials. My bias 38.5x14.5x16 are getting close to done with only 13k on them. Or you can get some smaller, cheaper tires for the in town and use the bias ply for the trail.
  4. tin man
    tin man 1/2 ton status
    Nov 11, 2000
    149
    Roselodge Oregon
    I had bias ply 36" tires. I hated them. No road manners at all. My truck felt like a caddy after I got some radials back on it.
  5. tweek
    tweek 1/2 ton status
    Aug 13, 2003
    353
    montgomery, ny
    don't forget it gets cold in our neck of the woods and it takes forever for them to round out..........................................
    felt like i was in a paint shaking machine on my 3 mile commute:o
  6. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Go for the Bias-Plys. It is not like they are going to kill any one. You will be much happier if you get your truck rolling now, instead of throwing away too much time dreaming of radials in the future. I am probably going for a set of Bias-Ply Interco TSL's myself. When you buy the tires, make sure the tires are well balanced (soft pellets work the best [about 10 ounzes per-tire for 38" tires]). Good balancing of tires makes a world of difference, on how good a truck feels rolling down the road.
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    TSL also drag down the gas mileage due to a much higher rolling resistance. I ran on a set of 36" bias TSL's for a month and couldn't wait to pull them off.
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    When it comes to tires in the 38" range, the radial vs. bias debut almost becomes a moot point when it comes to highway driving. The problem is not that the tires are bias, but bias tires in that size are almost always super aggressive like a Swamper.
  9. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    well said, this is the real issue
  10. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    I drive my bias swampers every day. To me it's no big thing, If I wanted a caddy ride I'd drive a caddy.
  11. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    awesome guys, thanks for the input:bow: ...i think ill be checking into some air soft pellets...and some new bias tires.:D
  12. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    My Iroks are my first set of bias tires. I've said it before, they ride better than the 35" BFG MT's or the 38" SSR's that I had before, and these don't have any balancing what so ever. I can't speak for other style bias tires, but these don't even get flatspots when parked for a couple days.
  13. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    i had 38x12.50x16.5 tsl tires on a 6500 lbs truck. were all good in less than 5 miles at the most. average was 2 miles. then flat spots were gone.
  14. eagle mark
    eagle mark 1/2 ton status
    Nov 18, 2004
    3,289
    North Idaho!
    I've run Swamper TSl and Boggers on the street, they both suck! Get radials!
  15. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    What size are you running (15 or 16 inch wheel)? If its the size in the sig, cool. I'm looking at IROKS that size.
